m3 e92 with ap racing brake
01-30-2013, 10:57 PM | #1 |
24
Rep 132
I installed Ap racing brake kit before track day, it works perfectly on the track, but I found noise problem after track.
I totally understand and accept the brake pad will squeal when I slightly brake it under low speed , but now the problem is , after I make complete stop, release brake and start moving, I can feel the front pad still rub the roter make the entire car under high frequency vibration, the vibration feels exactly like the noises when you push a table on a concrete surface. Usually the vibration will goes away when the speed is over 10 mph (keep wheel straight) , and will come out when I make turns around 25-30 mph after brake(on the ramp to exit freeway or make turns at intersection) . Any one has experience on this?? is this normal?? |
01-31-2013, 02:41 AM | #3 |
73
Rep 963
Fifteen years ago or so I had to copper grease my first car's brakes once a month or I got the brake binding like you, same thing. Fiat Uno though so hopefully yours doesn't need such regular TLC
