KW Variant 1 broken endlink tab
01-29-2013, 08:44 PM | #1 |
13
Rep 50
I just purchased a set a KW V1 coilovers for a great deal. The only catch was that the endlink tab on the front passenger strut snapped off and needed to be re-welded. I was fine with the idea of welding the tab, but the more i talk about it the more uncomfortable the idea sounds. Do you guys think a good shop can re-weld and brace the tab? The other alternative would be to send the strut back to KW for a $300 rebuild.
01-29-2013, 09:14 PM | #2 |
12
Rep 231
If done right a weld can be stronger than the surrounding metal so I don't see an issue. I would certainly take it to a reputable shop or if your lucky you know of a welder who will do it on the side. If there is a risk of KW not doing a rebuild after it's been rewelded maybe that's something to consider. I have no clue if they would take that avenue, just putting it out there.
01-29-2013, 09:42 PM | #3 | |
Bausman
63
Rep 1,817
01-29-2013, 10:44 PM | #4 |
just another bmw douche bag
195
Rep 3,640
rewelding is fine as long as it's done properly.
if you send the shock in to get revalved, send both fronts in, not just one. otherwise the damping may not match since the other shock will be worn and the rebuilt one is essentially new on the inside. |
01-30-2013, 01:09 AM | #5 |
79
Rep 2,110
Try getting it welded first. If that fails, which I don't see happening, then go for the rebuild. And yes like others have said, if you do get a rebuild done make sure both fronts get rebuilt.
01-30-2013, 10:25 PM | #6 | |
111
Rep 1,764
02-02-2013, 09:40 AM | #8 | |
13
Rep 50
02-02-2013, 12:28 PM | #9 | |
111
Rep 1,764
02-03-2013, 09:02 AM | #10 | |
13
Rep 50
02-04-2014, 05:39 PM | #11 |
اوليسيس
196
Rep 4,678
Did the OP get this resolved? I'm sending in my original set and am expecting some resistance from KW.
Orb,tried PM you, but no go on this. It won't let me for some reason.
02-06-2014, 05:26 PM | #13 |
13
Rep 50
I still haven't done anything with my coilovers. When i talked to them on the phone, they didn't seem to have any issues rebuilding the housings.
02-06-2014, 05:28 PM | #14 |
13
Rep 50
02-07-2014, 03:34 PM | #16 |
8
Rep 158
I just rewelded mine a few months ago. I originally called kW and they wouldn't honor the warranty. Instead said they would sell me a new coilover for x amount and never mentioned a rebuild...
Just pull it out and have somebody tig it back. Shouldn't cost more than 40 bucks. |
