F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > New Release - BMW F30 328i - Meisterschaft Exhaust
GetBMWParts
      01-29-2013, 04:42 PM   #1
GTHAUS
GTHAUS's Avatar
Drives: G82 M4
BIMMERPOST
     Featured on BIMMERPOST.com
Above: BMW F30 328i with Meisterschaft 2x83mm GTC (EV Control)
Presenting Meisterschaft premium exhaust systems for the BMW F30 328i. Artfully designed and scrupulously engineered, our GTC (EV Control) and GTS (Ultimate Performance) exhaust systems for the 328i provide a solid performance gain and exotic exhaust note that any Bimmer enthusiast will enjoy. As is the case with many of our BMW exhaust units, we offer a variety of tip styles and performance options to suit each individuals taste. The tips are also adjustable to provide the perfect fit.
Above: BMW F30 328i Meisterschaft 4x90mm GTC (EV Control)
Above: BMW F30 328i Meisterschaft 2x83mm GTC (EV Control)
All Meisterschaft rear muffler units for the 328i include our SR (resonator delete) pipe in stainless steel. In addition, our optional AR pipe, which connects from the primary catalytic convertor to the connecting SR pipe, has been designed to enhance the exhaust flow and eliminate cutting into the OEM exhaust during installation. The combination of our Meisterschaft rear muffler section, SR pipe, and AR pipe creates a full primary cat-back exhaust system that is optimized to provide optimal flow and maximum performance gain.
Above: BMW F30 328i Meisterschaft AR Pipe
Above: BMW F30 328i Meisterschaft 2x83mm GTS (Ultimate Performance) + AR Pipe
GTS vs. GTC Exhaust System:
Meisterschaft engineered the GTS (Ultimate Sport Performance) and the GTC (EV Control) exhaust systems for the 328i to provide as much performance gain as one can receive from an exhaust system alone while at the same time intensifying the vehicle’s exotic exhaust note.
The main difference between the two systems is that the GTC (EV Control) is equipped with electronically controlled valves.
Electronically Controlled Valves:
Meisterschaft GTC (EV Control) exhaust system for the 328i includes electronically controlled valves which open and close with a wired switch inside the vehicle cabin (or by our optional wireless remote). With electronically controlled valves, you are given the option of controlling the sound level and also performance output of your 328i.
Keep the valves closed if you prefer a modest, near stock sound to emit from your exhaust or simply open the valves if your wish is to maximize both sound and performance output.
Above: BMW F30 328i Meisterschaft 4x90mm GTS (Ultimate Performance)
Build Quality and Material:
Only the highest grade T304/T316 stainless steel is used for the construction of Meisterschaft stainless steel exhaust systems. Plasma cutting and laser welding techniques are utilized and handled with extreme care. The highest grade and the most durable glass wool pack, which can withstand extreme temperatures and conditions, is used for the internal construction.
Here are a few images of the units being installed:
Above: BMW F30 328i Meisterschaft Install
Above: BMW F30 328i Meisterschaft 4x90mm GTC (EV Control) Install
Above: BMW F30 328i Meisterschaft 2x83mm GTC (EV Control) Install
And for those of who prefer video over stills, here you are!
The first video compares the F30 328i Oem exhaust with our cat-back Meisterschaft dual tip 2x83mm GTC (EV Control) exhaust.
The second video compares the F30 328i OEM exhaust with our cat-back Meisterschaft quad tip 4x83mm GTC (EV Control) exhaust.
Also, we made two more additional videos of the 328i that feature our TURBO-BACK system w/ Meisterschaft cat-less downpipe! You can view them here: http://www.youtube.com/user/eisenhaus
      01-29-2013, 04:57 PM   #2
slmdgee
Usofstance
Drives: 328I 6SPD
I just wish i can afford this exhaust.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      01-29-2013, 05:24 PM   #3
JOHN328
Feeling horny
Australia
36
Drives: BMW F30 328
Sick. Can u make rev and fly by videos?
Want to have a listen before I buy.
      01-30-2013, 11:08 AM   #4
gicode0823
Drives: 328i
x2 for the vids!
      01-30-2013, 02:59 PM   #5
Axxlrod
Dude man
Axxlrod's Avatar
164
Drives: X5/X7/Acura NSX
Pics are great and all, but we need to hear it.
      01-30-2013, 03:43 PM   #6
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
That valve control is an awesome option!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      01-30-2013, 03:44 PM   #7
Nero7
Nero7's Avatar
53
Drives: F30 M-Sport 328i
Very beautiful exhaust system , would love to hear some rev and launch videos . How much is the perfomance gain and weight compared to stock and M-Perfomance exhaust?
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display ///
      01-30-2013, 10:36 PM   #8
Casualvic
26
Drives: 328i xdrive
looks like something ironman put together, you get it...the welds and stuff?
      01-30-2013, 11:18 PM   #9
DesertSmokeBBQ
DesertSmokeBBQ's Avatar
Drives: 2014 F30 335i M-Sport
2013 BMW  [0.00]
4X90mm, would LOVE to hear it, also, M-Sport rear diffuser in carbon to match?
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP
Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL
      01-31-2013, 02:02 AM   #10
zibawal
Drives: 2012 X5D
Any video of sound? Where to buy? And any sponsor?
      01-31-2013, 05:01 AM   #11
7 4 7
7 4 7's Avatar
India
127
Drives: E46 328i, F30 328i, G20 M340i
I like what i see
Wish i could hear what i see too
BMW F30 328i (A/T) | Toyota Fortuner 4x4 (M/T) | Toyota Hyryder Hybrid (e-CVT) | BMW G20 M340i | Skoda Kushaq (A/T) | Kia Seltos (DCT) | BMW E46 328i (M/T)
      01-31-2013, 12:36 PM   #12
slmdgee
Usofstance
Drives: 328I 6SPD
sound clips
      01-31-2013, 12:57 PM   #13
soolman32
soolman32's Avatar
Drives: Current: F30 335i Soon: AMG
+ 1 to this. Wonder how much the full system will run.... Definitely interested regardless.
      01-31-2013, 01:00 PM   #14
slmdgee
Usofstance
Drives: 328I 6SPD
Just spoke to them and its going to cost 2500 for the quad tip. They will be releasing the sound clips in a few days.
      01-31-2013, 02:46 PM   #15
soolman32
soolman32's Avatar
Originally Posted by GTHAUS View Post
Hello everybody! We will post a few exhaust comparison videos very shortly. If anybody is interested in pricing, please find the following link to the F30 328i exhaust section on our website. Thanks you!
http://gthaus.com/ver3_ghdetails.php...46&Submit.y=20
Thanks for the link. Looking forward to the sound clips.
      01-31-2013, 03:19 PM   #16
slmdgee
Usofstance
Drives: 328I 6SPD
      01-31-2013, 03:28 PM   #17
GTHAUS
GTHAUS's Avatar
Drives: G82 M4
As promised, here are two comparison videos!
The first video compares the F30 328i Oem exhaust with our CAT-BACK Meisterschaft dual tip 2x83mm GTC (EV Control) exhaust.
The second video compares the F30 328i OEM exhaust with our CAT-BACK Meisterschaft quad tip 4x83mm GTC (EV Control) exhaust.
Thanks for your interest!
      01-31-2013, 09:31 PM   #18
shivj
Drives: 2012 F30
Loving the electronic valve control, sounds great too. This is exactly what I was looking for since the 3 is my dd. Really great work on the exhaust. Definitely in for some numbers! When will ordering be available?
      01-31-2013, 11:39 PM   #19
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
Ok, so they sound great, no issue there. Thing is, can you please post proper dyno proof that your exhaust will offer some additional whp to the 328i. You have stated that it will add Kw & Nm, but so far, no numbers. Lots of $$$ to pay for extra (but very nice, I admit) noise.
Show me the numbers!!!! (LOL)
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      02-01-2013, 12:31 AM   #20
JOHN328
Feeling horny
Australia
36
Drives: BMW F30 328
Can we also have a video with dyno so we can hear the exhaust under engine load through out the gears.
U guys have done it for 335, m3 and m5s.
BMW F30 328i Sport Line
      02-04-2013, 01:48 PM   #21
chugster
B0$$
chugster's Avatar
Drives: 2020 HS M2C
is it possible to just order the downpipe by itself?
      02-04-2013, 01:58 PM   #22
zibawal
Drives: 2012 X5D
You men without performance exhaust and it shall sound good? And increase HP too
f30post
