ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      08-23-2007, 08:29 AM   #1
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
DIFF fluid Change
THIS DIY IS FOR 2003 Z4 2.5i MANUAL
do this when the car is fairly warm but not burning hot as you will be working near the exhaust. and again, dont' sue me if you make a mistake..and if you are not mechanically inclined, bring it to me i charge a lot
tools required
1)8mm socket wrench
2)jack
3) FOUR jack stands
4)1 quart of 75w-90 oil of your choice...mine being Mobile 1
5)Hand Pump
6)14mm hex socket. there's a DIY for this instead of buying. Honestly though, i forget if its 12 or 14 lol
My way of jacking up all four tires safely.
1)jack driver side only, put the jackstand under the lower control arm.
2)do the same on the passengerside
3)go to the rear, look at the center where the two bars come together and bolts on. Jack from there to a position and place jackstands under the factory jack location on the sides
1)get the car in the air. all 4 tires off, and in somewhat of a leveled position.
2)notice where you jacked up the car in the rear? well there is the silver covering, you need to remove the rear half of it by using 8mm socket wrench
3)when done, look for the FILL plug, it's kind of slanted...unscrew that with the 14mm hex socket.
4)then unscrew the DRAIN plug...oh don't forget to put something underneath to catch the oil and tighten drain plug
5)using the hand pump, pump diff oil in until it oozes out of the fill hole
6)again, take the car down in a safe manner, use a common sense and you are done!
      11-07-2010, 08:58 AM   #2
lstratos
8
Drives: Z4 3.0i
I just did this for my 07. The steps are exactly the same as your, nothing has change.
I had plan to just change the drain plug out to a new one but before I started, I found this dimple magnetic replacement plug, so I end up using my new drain as my filler and the dimple plug in the drain.
The dimple plug is very very strong, was really hard to get into the hole (insert thats what she said joke). The magnet kept sticking the body of the diff and took a little time to plug it the drain hole and screw in..
I end up using redline gear oil. The dimple plug was pretty expensive.. around 30.
As you guys can see my bottom is pretty rusted.. salt of north east can do that... Not driving it through snow or salt this year Should I sand that off and spray anti rust on that ?
      09-26-2012, 08:18 AM   #3
shakemyhand
Drives: 2007 Z4 Roadster 3.0i
tools required
1)8mm socket wrench
2)jack
3) FOUR jack stands
5)Hand Pump
Thank you for the pictures and the information. Mike
      09-26-2012, 08:21 AM   #4
shakemyhand
Thank you for the pictures and all the good information. Mike
      09-26-2012, 08:55 PM   #5
4dimnzn
Life choice to have lots of BMW's instead ex-wives
4dimnzn's Avatar
37
Drives: G87 M2 Z4M E46 Wagon 318ti
Nice job! I did my 05 Z4 on a lift a BMW CCA DIY clinic and had a heck of a time getting the right angle on the fill plug with a wrench. I had to move one of the support bars.
      09-26-2012, 11:35 PM   #6
bosstones
1154
Drives: o_0
I've been dragging my feet on doing this. I have all that I need except for a pump bottle. I was just going w/ the OE fluid. Also have some Synchromesh II that's waiting to go in the gearbox but.....haven't checked locally for a pump bottle.
      09-27-2012, 10:51 PM   #7
rsutoratosu
114
Drives: Z4 3.0i
on amazon they got tons of it.. I was just gonna go to my local costco / bj and see if they got the big shampoo bottle that comes with the pump and use that ill be pouring the shampoo out manually
-Roranji
      09-28-2012, 09:29 AM   #8
bosstones
1154
Drives: o_0
I saw some stuff up on Amazon when I searched a few weeks back but wanted to check locally as well. I was going to order a suction gun since that seemed to be quicker than a pump top but the one I looked at is out of stock now.
      09-28-2012, 01:36 PM   #9
rsutoratosu
114
Drives: Z4 3.0i
ooh never heard of suction gun, got me interested, i need to change my fluid again
-Roranji
      09-28-2012, 05:55 PM   #10
bosstones
1154
Drives: o_0
lol I came across them while looking on Amazon for pump bottles.
This is the one I was going to order, but it's out of stock now.
http://www.amazon.com/Lumax-LX-1185-...=pd_sbs_auto_1
Here's another but it's only got one review.
http://www.amazon.com/Powerbuilt-648...=pd_sbs_auto_2
      09-29-2012, 03:49 PM   #11
Incompatible
Drives: 07 AW Z4C 3.0Si
BlackSapphireZ, great write up, thanks for posting. What was your mileage when you did this?
lstratos, good additional info, complements BlackSapphireZ original post nicely. What was your mileage when you did yours?
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      09-29-2012, 09:40 PM   #12
rsutoratosu
114
Drives: Z4 3.0i
I did mine at around 30k, but I read some place every 2 years. I just hit 45k and 2 years now.
-Roranji
      10-07-2012, 10:18 PM   #13
bosstones
1154
Drives: o_0
Arg....got the Moupe up on stands and found out my 14mm hex driver bit is missing. Moved on to the gearbox......and found that I really do need a stubby 8mm hex bit. Not for torque purposes, but because I'll never fit my torque wrench in there w/ a standard length (Craftsman) bit.....tight fit!
      11-04-2012, 05:02 AM   #14
Yeggman
Drives: 2009 Z4 s3.0i 6MT
Excellent write up, with wonderful photos, thanks.
Thanks, again.
      11-16-2012, 05:34 AM   #15
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Quick question...
I plan on doing all the fluid changes very soon (once it all comes in the mail!) and am curious...for each oil, transmission, and diff...
Do I need to get new drain and/or fill plugs, or can I resue the old ones? I'd *like* to get all the magnetic ones, but I can't afford all of that right now...
Thanks.
      11-16-2012, 06:06 PM   #16
jmillet
jmillet's Avatar
63
Drives: 2023 Hyundai IONIQ 6 SEL AWD
The differential and transmission plugs are one-use o-ring type plugs. You'll need a very stubby 8mm hex bit 3/8ths drive socket to access the transmission fill plug.The Matco BXYS8M does the job:
http://www.matcotools.com/catalog/pr...EX-BIT-SOCKET/
Originally Posted by 007MCoupe View Post
Quick question...
Thanks.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      11-16-2012, 11:22 PM   #17
bosstones
1154
Drives: o_0
Oil drain plugs are reusable, but you need a new crush washer. The washer should come w/ the filter change kit, along w/ a few other bits as well.
      12-10-2012, 11:51 AM   #18
david_m
Drives: 2003 BMW Z4 2.5i
This is an awesome write up. Will be doing mine in the near future.
      12-11-2012, 11:23 AM   #19
aerobod
Car Geek
aerobod's Avatar
3612
Drives: Caterham R500, M2-G87, Macan S
On the Z4M there are no crush washers on the transmission or differential fill or drain plugs. They are all one-use plugs with built-in 'O' rings.
      12-12-2012, 08:49 PM   #20
bosstones
1154
Drives: o_0
Sorry, should've been more specific since they're all oils. I was referring to the drain plug for the oil pan (engine oil). Trans and diff get new plugs.
      12-13-2012, 11:51 AM   #21
Ovaltine
floor sweeper
Drives: 2007 Z4 Coupe
Had planned to do this last weekend and quickly saw that my diff does not have a drain plug ('07 Coupe). It's even a different differential casting than the one pictured above, as in there's no boss where the plug should be.
      12-30-2012, 09:51 AM   #22
vachss
55
Drives: Z4 Coupe
E90 folks seem to use oil extractors for this and do everything through the filler hole. http://www.e90post.com/forums/showthread.php?t=385975
zpost
