ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      08-23-2007, 08:21 AM   #1
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
Trans Fluid Change
THIS DIY IS FOR 2003 Z4 2.5i MANUAL
do this when the car is fairly warm but not burning hot as you will be working near the exhaust. and again, dont' sue me if you make a mistake..and if you are not mechanically inclined, bring it to me i charge a lot
tools required
1)17mm wrench
2)jack
3) FOUR jack stands
4)2 quarts of Redline ATF D4 fluids yes it's an ATF for a Manual car
5)Hand Pump
My way of jacking up all four tires safely.
1)jack driver side only, put the jackstand under the lower control arm.
2)do the same on the passengerside
3)go to the rear, look at the center where the two bars come together and bolts on. Jack from there to a position and place jackstands under the factory jack location on the sides
1)get the car in the air. all 4 tires off, and in somewhat of a leveled position.
2)locate the tranny FILL bolt on the side, unbolt first!!! and then place a catch can under the DRAIN bolt, and unbolt. it will shoot out
3)when finished draining, tighten drain bolt and proceed to fill the trans with Redline ATF D4 fluid using a hand pump
4)as you start seeing the fluid ooze out of the fill hole, tighten FILL bolt
5) take the car down in a safe manner, use a common sense and you are done!
      03-28-2014, 12:17 AM   #2
dwn2thalastroach
Drives: '16 M4
Slightly different plugs but also applies to my 3.0i
      04-13-2014, 06:32 PM   #3
rkstar9
75
Drives: '10 X5 3.5D
Nice thank you for tutorial,
I found that my old oil looked like water. replaced it with royal purple synchromax
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
Search this Thread:
Advanced Search
zpost
