INPA - Complete frustration
01-27-2013, 08:44 AM | #1 |
65
Rep 72
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Garage List 2021 BMW X6 M50 [0.00]
2018 Porsche 911 GT3 [0.00] 2015 BMW i8 [0.00] 2008 BMW M Coupe [0.00] 2017 Porsche 911 Tu ... [0.00] 1986 Porsche 911 Sl ... [0.00] 2021 BMW Alpina XB7 [0.00] |
All, I am ready to throw my computer out the window at this point...this is maddening! I have programmed several FXX cars with ESys, so fundamentally I know how to code, however I have set everything up (although everything is still in German!!!@#@#%!@), I open INPA, I get both black dots, however I only F1-Info F2-Script and F10-End, none of the other "F" keys are populated. I have copied all of the daten/ecu/sgdat files over to their respective folders. Please help!
01-27-2013, 09:01 AM | #2 | |
441
Rep 18,331
http://www.e90post.com/forums/showthread.php?t=645844 |
01-27-2013, 08:17 PM | #3 | |
65
Rep 72
01-27-2013, 08:38 PM | #4 |
441
Rep 18,331
download his link for software and use it....replace your files with his...His is in german though I believe but it works.
01-28-2013, 12:20 AM | #5 |
Guest
Rep n/a
Drives:
When you installed INPA, your suppose to run a file called Reference2006.exe or something similar, this installs the proper files and you should see all the options.
As far as it being in german you have the wrong version, I PM'ed you the link you need with the correct software and detailed step-by-step instructions. Good luck. |
01-28-2013, 10:16 AM | #7 | |
535
Rep 1,873
Find another INPA package. My current issue is that I can't get MSV70 or MSV80 stuff in English and I've tried many different packages and every "how to" out there trying to get English to work.... |
01-28-2013, 06:18 PM | #8 |
24
Rep 355
Try this
