F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding Help!!
GetBMWParts
      01-23-2013, 08:18 PM   #1
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
Coding Help!!
Hi All,
I have been through the PDF with step by step instructions however after clicking "Code FDL" it runs through and gives me the following error:
Just trying to code our the disclaimer. The default was set to permanent so i set it to Kein_id.
Also the folder was named HU_CLAMP2. I could not find HU_CIC as per the cheat sheet
Car is 2012 328i
[HU_CHAMP2 - 63] prepareECUforCoding started
[HU_CHAMP2 - 63] prepareECUforCoding error
[HU_CHAMP2 - 63] finalizeECUCoding started
[HU_CHAMP2 - 63] finalizeECUCoding finished
[Exception - HU_CHAMP2 - 63] Exception occurred: job failed with negative response error:
code: written data does not match read data
description: no detailed description available; ECU: HU_CHAMP2_63_ETHERNET
severity: ERROR
Timestamp: Thu Jan 24 12:49:39 EST 2013
ErrorCategory: VEHICLE_ERROR ID: 433
      01-23-2013, 10:06 PM   #2
Frogman
Drives: 2012 F30 328i
Originally Posted by mrtanz View Post
Hi All,
Car is 2012 328i
severity: ERROR
This is the exact same error I got when trying to code with 48.3 using the old "Code Away" token.
You need to get a new E-Sys token. I also upgraded to 3.22.5 at the same time as the token is tied to the E-Sys release.
Read this thread here:
http://www.bimmerfest.com/forums/sho...7&postcount=46
      01-23-2013, 11:24 PM   #3
mrtanz
Australia
24
Thanks
Where can i source the new token
i am on 3.18.4
      01-23-2013, 11:35 PM   #4
Frogman
Thanks
i am on 3.18.4
You need to contact the poster of the thread I referenced.
      01-25-2013, 01:40 AM   #5
mrtanz
Australia
24
Thanks everyone for your help
Problem is fixed with new token
      03-20-2013, 02:28 AM   #6
deniza
Russian Federation
Drives: BMW F30 320d
Read this:
Name:  Screen Shot 2013-03-21 at 11.28.08 AM.jpg
I've bought both CIC and NBT modules just before my car was arrived. In ETK from 01 Dec 2012 F30 should be equipped with NBT headunit, but I found later in ETK from 01 Feb 2013 F30 car is equipped by ordinary CIC. May I install NBT anyway on my car and code it by using E-sys 3.18.4 with latest PSDZdata or do I need 3.22.5 to do coding?
My car was produced on 17 Jan 2013.
For now I have radio professional installed with small 6,5" display and standard instrument cluster (small LCD display).
Thanks.
      03-20-2013, 02:31 AM   #7
deniza
Russian Federation
Mrtanz, do you have E-sys 3.22.5 with compatible pin to make a coding? I have 3.18.4, but as I read before it is not enougth to code cars start from 2013 year of production.
f30post
