This code...
01-22-2013, 10:04 AM | #1 |
138
Rep 571
This code...
2D18 manipulation cover maximum air mass..
every time when i hit full throttle on map2 this code appear then the car come back to stock even if i choose map2 no boost even if i delete the code it's come back again and again...plz what to do |
01-22-2013, 10:55 AM | #2 |
161
Rep 7,377
thats a tuner code. what tune do you use?
01-22-2013, 11:44 AM | #4 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
01-22-2013, 05:20 PM | #5 | |
138
Rep 571
I use G4, what's the best number for loop to avoid this code ? |
01-22-2013, 07:22 PM | #6 |
40
Rep 623
When I was on the G4 board I used a fuel open loop at 80. But this was only because Im mixing E85 and 93. If your using regular 93 octane fuel I dont know if you should be having this issue... What mods do you have on your car? If I'm not mistaken, you need to set futureuserA to something so it holds your open loop setting to whatever you set it to. Go to n54tech.com to check it out to make sure what the right settings to set fuel open loop mapping. I forgot because I'm on G5 ISO now for a while.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
