Pre-Lci E90 Sedan Tires
01-19-2013, 02:56 PM | #1 |
50
Rep 1,731
I've been doing some searching and there's no definitive answer of sizes going past 245/35/19 in the front and 275/30/19 in the rear...I am willing to roll my fenders and play around with camber (-2.2!). Currently, the car sits at 245s in the fronts and 275s in the rears (no rubbing even in big dips). I have rubbed occasionally with 5mm spacers and a full trunk. The reason is because I have weak/OEM offsets (35mm F, 38mm R).
My thought was running 255 or 265s in the Front and 295/30/19 in the rear. Yes, LSD is in the near future...but I want a set of sticky yokohama advan neova ad08s (which I've been told run a size bigger ))) Any pre-lci sedan owners wanna chime in and their big tire setups? |
01-19-2013, 06:05 PM | #2 |
453
Rep 2,973
Hi,
I run 275/30 in the rear of my car with +35 offset. The 295 is a 1cm wider on both sides. I don't think it will fit without a fender pull. I don't think rolling the fender will be enough. It's also going to be taller. I'd love to see it if you can make it work. |
01-19-2013, 06:56 PM | #3 |
50
Rep 1,731
I guess you might be right, 275s fit fine without any work so I'm thinking what the hey lol
01-19-2013, 06:57 PM | #4 |
///M at Heart
90
Rep 1,954
I think 285's are as wide as you can go without rolling.
we'll find out come spring lol. I plan on running 255/35 fronts, 285/30 rears. ET +18 up front (I am VERY likely going to have to roll the fenders, and +34 on the rear. |
01-19-2013, 07:54 PM | #5 |
50
Rep 1,731
Yeah you might have to pull your fenders lol. Mods, can you switch this to tires forum? If not ill just copy and paste into a new thread
01-20-2013, 02:59 AM | #6 | |
LCI'd
257
Rep 819
Or so I was told... |
01-20-2013, 04:29 AM | #7 |
50
Rep 1,731
False, sedan front fenders are metal
01-20-2013, 01:36 PM | #8 |
14
Rep 455
anything over 245 in front will need fender pull and camber.
295 with fender pull is possible. might rub a lil over bumps with passengers in the rear seat. drawback: if ever you wish to change wheel setup to square after getting LSD, fenders cant be un-rolled. for 2years i drove my car with staggered 245/275 with fender pulled. now i run 245squared and e joy driving the car much more. better faster crisper turn in and being able to.rotate.tires.is a big plus.have to run 25mm spacers to cover the hidious arch gap in the rear tho
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
01-20-2013, 05:36 PM | #9 |
50
Rep 1,731
Haha even with a LSD, I will most likely remain with 255/295. With Yokohamas running a size wide, it may be a true 265/305 LOL.
If not, then I guess I'll run 245 (a true 255) in the front. 245 DWS doesn't rub at all. |
01-20-2013, 10:22 PM | #10 |
///M at Heart
90
Rep 1,954
01-21-2013, 08:13 PM | #11 |
50
Rep 1,731
Sedan fenders (Front and Rear) are metal. See Post #7.
04-24-2013, 11:53 PM | #12 |
50
Rep 1,731
Well 295s fit, rubs a bit but only over big bumps.
255s fit perfect, no rolling necessary. EDIT- Now I wonder if I can get away with +20/+22 offset F/R with these sizes lol....gonna buy some spacers and experiment. |
04-25-2013, 08:26 PM | #14 |
50
Rep 1,731
Yeah haha, I feel I need a pull in addition to the roll
04-26-2013, 12:43 PM | #16 |
50
Rep 1,731
Yeah that was my old setup haha
04-26-2013, 10:48 PM | #17 |
DIYER
614
Rep 5,521
I run a 295 with a 5MM spacer with a fender roll plus a bit of grinding to get the roll flatter abs have plenty of room...I Ann going to a 305 here soon. No pulling needed.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
04-26-2013, 10:54 PM | #18 |
DIYER
614
Rep 5,521
They are metal, but are plastic on front clip which is where I shaved some material.
05-05-2013, 12:32 AM | #19 |
50
Rep 1,731
Not bad |
05-05-2013, 09:21 AM | #20 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
This is correct! I am running a 275 right now on a 10 inch wheel and the tire looks a bit stretched. I can most definitely get a 285 in there, but then there *might* be a slight rub in the fender liner.
I have the OEM sport suspension.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
05-06-2013, 02:44 AM | #21 |
79
Rep 2,110
Damn must be nice only worrying about tire size. Haha
I finally was able to get my 18 x 12" with a 285/30 to fit without rubbing. Rear fender lip has been cut clear off, then sanded after. Really the only way to go, way more room compared to just a roll |
05-06-2013, 03:08 AM | #22 | |
DIYER
614
Rep 5,521
roll and it thinned out the metal and I was able to bend it in more but I want the lip gone....doesn't seem to hard to do and will allow for more clearance.
