5MM spacer question
01-16-2013, 09:46 PM | #1 |
DIYER
614
Rep 5,521
5MM spacer question
I have basically new lugs, just got coilovers and my rim barley scuffs the coilover (white line on rim) and I am guessing I have to use a 5MM spacer. Is there a spacer less than 5MM? Do I really need longer bolts with such a small spacer?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
01-16-2013, 09:54 PM | #2 |
DIYER
614
Rep 5,521
I am getting new bolts so scratch that question.
01-16-2013, 10:06 PM | #3 |
DIYER
614
Rep 5,521
you guys think the 2MM or 3MM would be best to keep rim from barely rubbing strutt? I have never used spacers and would like o use as least as possible. If I use spacers in front do I have to do this in back also?
2MM: http://www.ecstuning.com/BMW-E90-335...acers/ES11201/ 3MM: http://www.ecstuning.com/BMW-E90-335...acers/ES11294/
01-19-2013, 08:27 PM | #4 |
125
Rep 3,004
I am using 5mm spacers with stock Lugs without issues for the last 2 years.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
01-25-2013, 03:20 PM | #9 |
Rep 177
I've seen high quality 5mm aluminum spacers for less than $50.
01-25-2013, 11:38 PM | #10 |
DIYER
614
Rep 5,521
I went with the 3MM since I have pretty aggressive wheels...had to shave the front fenders without the spacers lol!!
01-26-2013, 12:05 AM | #11 |
149
Rep 6,604
Drives: e92 335i
5mm is not going to make any visual difference.
01-26-2013, 02:56 PM | #12 |
1559
Rep 4,109
Drives: BMW M3
VAC makes high quality spacers & extended lug kits:
http://store.vacmotorsports.com/vac-...its-p1587.aspx I would get extended lugs with any spacer to be on the safe side (or a stud kit). I have F/R spacers from VAC on my car. Beautifully machined and not expensive.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
