Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Comfortable coilover options.
      01-16-2013, 11:13 AM   #1
melenkae90
melenkae90's Avatar
8
Drives: 2007 e90
Just trying to see which coil over options are out there that are on the comfortable side? Anyone with experience with ohlins, kw street comfort....etc
      01-16-2013, 12:21 PM   #2
Blaster400
Blaster400's Avatar
127
Drives: BMW X3 35i, Porsche Macan S
I just installed Öhlins and they ride even better than stock with greatly increased performance. Highly recommended.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
      01-16-2013, 01:41 PM   #3
melenkae90
melenkae90's Avatar
8
Drives: 2007 e90
Did you run the supplied springs?
      01-16-2013, 01:58 PM   #4
jyeah
30
Drives: 2010 BMW 335i
I'm currently running it with the supplied springs and I would agree at 20 clicks from the hardest setting, it does have a decent ride quality.
      01-16-2013, 01:58 PM   #5
Phil325i
Phil325i's Avatar
United Kingdom
616
Drives: E92 325i MSport Coupe
+1
And yes, with the supplied springs...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      01-16-2013, 01:59 PM   #6
Blaster400
Blaster400's Avatar
127
I went with Swift Springs 336F/672R. Others including Alpina have used supplied kit springs with good success. For a daily driver where ride comfort is important I'd just go with the kit springs.
      01-16-2013, 06:10 PM   #7
Techevo
Evo Junkie
35
Drives: E91 325D M-Sport, Evo 6
I ran standard M-sport suspension on my E91, then replaced with Koni yellow sports and Eibach springs, and adjusting to midway damping position found them to be way, way more comfortable than the M-sport stuff.
Infact, for me, the suspension was too soft, so have replaced with Ohlins DFV, custom spring rates (350/700), uprated anti-roll bars and all M3 replacement arms and bushes. The ride is now far more controlled, not harsh or hard, but has an extremely controlled and quality feel about it. Far nicer than stock.
