Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Headlight auto level function after M3 rear chamber arm mod
      01-16-2013, 08:29 AM   #1
e679
e679's Avatar
Hong Kong
9
Drives: E93
Has anyone upgraded to M3 rear camber arm and retained the headlight leveling function?
I did some research and find some owner custom fab their lower m3 bracket.
However, anyone have use the upper sensor mount, switch the lever to other side? need coding this way?
Please share. Thanks in advance.
E93 335i Alpine White, 19" Works, PSS, M3 arms, M3 bushings,M3 E93 FSB/E92 RSB, powerflex rear diff bush.
AST 5100 with M3 rear camber arms. GC street plates.
      01-16-2013, 08:56 AM   #2
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
Check with Harold at HP Autowerks (vendor on the forum). He has a solution for this upgrade.
      01-16-2013, 09:06 AM   #3
e679
e679's Avatar
Hong Kong
9
Drives: E93
Thanks, I know that his rear chamber kit comes with a custom fab bracket but I would like to know how others solve this issue.
      01-20-2013, 09:50 PM   #4
Orb
111
Drives: 335
The HP custom bracket in question is not required and never was. I know this because I designed the custom bracket in question. I relied on bad inspection info from HP so big mistake on my part. This part should have never been made and is not required. In short, I am now using the OEM M3 brackets. You can thank a member on this forum who sorted it with the link below:
http://www.e90post.com/forums/showpo...0&postcount=14
      01-20-2013, 10:18 PM   #5
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
Originally Posted by Orb View Post
The HP custom bracket in question is not required and never was. I know this because I designed the custom bracket in question. I relied on bad inspection info from HP so big mistake on my part. This part should have never been made and is not required. In short, I am now using the OEM M3 brackets. You can thank a member on this forum who sorted it out so you should be able to find the thread.
Yo Orb - Fab'd brackets to use 335i leveling device with M3 bracket, otherwise didn't at all mate. Would have to flip the device, which may or may not [likely] have worked, or buy the M3 device. My Ace Hardware kludge working well, however.
What was your solution?
And what is that device anyway? Assumed a pot, but might be an optical encoder....?
      01-21-2013, 10:20 AM   #6
e679
e679's Avatar
Hong Kong
9
Drives: E93
Hi Orb, since when turning the sensor's arm 180deg. The anti-clock wise motion became clock-wise (when the spring compress). Will this turn the auto leveling up side down?
Need coding to fix?
I've tried to search very hard in this forum but couldn't find my answer. Really hope you can share your knowledge. Thanks
      01-21-2013, 10:27 AM   #7
e679
e679's Avatar
Hong Kong
9
Drives: E93
Hi Calwaterboy. I have check the M3 & 335 leveling sensors and they have identical part number within a same production period. So I bet we can use our old rear sensor with the M3 oem bracket.
      05-30-2013, 09:35 AM   #8
335dFan
Jumping Jack Flash
335dFan's Avatar
Drives: 2021 X3 M40i
Since having the work done shown in my signature block, my headlights have been shining much too high. Supposedly an item to deal with this came in the M3 rear goodies kit from Tischer, but it didn't work. So they either installed it incorrectly or the item is not right. The only thing the shop has been able to do is manually lower my beams slightly using a front adjustment. This is a very high end shop, but that pertains to engine and suspension work, not these fine details.
Any ideas?
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      05-30-2013, 03:49 PM   #9
CALWATERBOY
146
Any ideas?
Make the bracket - scroll way down to it or search post for: "Sensor arm needs to be rotated 180°" - adjust headlights. An easy fab, takes a small ammt of effort. Much less trouble than noodling with the leveling electronics.
Still working. No worries. No further maint.
      05-30-2013, 07:22 PM   #10
335dFan
Jumping Jack Flash
335dFan's Avatar
I am now an aging klutz so I won't do it myself, but I will show it to the shop, who does a lot of fab work. This would be a no brainer for them.
Thanks.
      05-30-2013, 09:08 PM   #11
CJ421
CJ421's Avatar
1559
Drives: BMW M3
I got my M3 rear camber arms from Harold @ HPA, it came with the piece CALWATERBOY mentioned you can make - works great. Probably simple enough to make.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      05-31-2013, 01:01 AM   #12
CALWATERBOY
146
A trip to Ace Hardware'll solve the problem.
