Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 9,5x19 ET45 or ET33 front? someone?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      01-05-2013, 11:57 AM   #1
M KonZepT
M KonZepT's Avatar
Spain
10
Drives: 335i E93
2007 335i E93  [9.00]
9,5x19 ET33 front? someone?
Hi,
iīm thinking to put in my E93 this wheels configuration:
9,5x19 ET33 front
9,5x19 ET20 rear
I know that i will havenīt problems rear but front i donīt know. Someone has mounted this size?
Thanks and sorry for my bad english.
      01-05-2013, 01:45 PM   #2
project335i
144
Drives: Wide Load
Front will be sunk in with that offset I suggest you get spacers all around the rear is not the greatest either
      01-05-2013, 02:24 PM   #3
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
Front will hit the struts inside. I have 18x9.5 et35 front and that's around 2mm from stock shocks.If you have coilovers you need even more lower offset.
      01-05-2013, 03:42 PM   #4
M KonZepT
M KonZepT's Avatar
Spain
10
Drives: 335i E93
My car have KW VII. 9,5x19 ET33 itīs possible too. The wheels i choose are the VMR V713.
      01-06-2013, 11:31 AM   #5
MonacoBlueE90
Finland
163
So you have coilovers.Then definitely you choose the 19x9.5 et33 with 235/35/19. If that doesn't clear the coilovers. You can get 3-5mm spacer. I have no experience 9.5 front fitment with coilovers, only with stock shocks which are more narrow than coilovers.
      01-06-2013, 09:36 PM   #6
edirtaynine
81
Drives: e92
you're going to need at least small spacers for the +33mm offset. the +45, you shouldn't even bother to begin with. +45 wheels will look dumb on any suspension setup.
e90post killed plastidip
Just say no to painted stock wheels
jm3as hooks it up
      01-19-2013, 01:31 PM   #7
M KonZepT
M KonZepT's Avatar
Spain
10
Drives: 335i E93
Thanks for the answers.
Someone with 9,5x19 ET33 + Coilovers?
      01-20-2013, 12:41 AM   #8
MonacoBlueE90
Finland
163
Here is one
http://www.e90post.com/forums/showthread.php?t=602677
      01-20-2013, 04:46 AM   #9
M KonZepT
M KonZepT's Avatar
Spain
10
Drives: 335i E93
Originally Posted by MonacoBlueE90 View Post
Thanks Monaco, iīm talking with Ken
      01-20-2013, 10:25 AM   #10
MonacoBlueE90
Finland
163
Your ,welcome.Hope he can help you better.
All i can say that the 2mm gap between struts and wheel that i have didn't cause any problems last summer. Of course if you bend your wheel it might start to hit the struts.
