Seat Creak
01-02-2013, 09:17 AM | #1 |
56
Rep 1,255
Seat Creak
My drivers seat seems to have developed a 'creak', sounds like a dry spring coming from the back rest part of the seat. I'm assuming something needs lubing or a spring requires replacing, wondering if anyone has any experience of this or where the best sections to lube are. I say it seems to be the back rest part as if you lean in and but pressure on the rear of the seat (no weight in the seat itself) you can hear it.... quite annoying. |
01-02-2013, 10:34 AM | #2 |
32
Rep 1,271
Drives: 335i (sadly gone)
I had a very similar creak with my passenger seat. Spent ages trying to figure out what it was as putting weight changing the position had no effect. It turned out to be the head rest had been moved (up/down) and not clicked into place properly.
01-03-2013, 02:43 AM | #3 |
56
Rep 1,255
If only it was that easy
Resat the headrest but I do think its coming from the lower hinge part of the back rest where it meets the base by the seat belt buckle........gonna have to go bananas with the WD40. |
01-03-2013, 04:57 AM | #4 |
3533
Rep 11,292
I had a seat squeak for a while and finally realised it was coming from underneath the seat belt receiver buckle and not the seat at all. When I drove along and put my hand below the buckle I could feel the creaking.
To fix, just spray loads of WD40 into the top of the seat belt buckle, it will find its way down. No need to take anything apart. |
01-03-2013, 05:14 AM | #5 |
56
Rep 1,255
Cool.
Found these threads too http://www.e90post.com/forums/showthread.php?t=326052 & http://www.bimmerfest.com/forums/sho...0&postcount=10 Gonna go crazy with the WD this weekend |
01-03-2013, 07:06 AM | #6 |
32
Rep 817
I have got the same thing - I think it is a leather meets plastic problem. Don't waste your time with wd40 - have a go with silicone spray - did mine and it got rid of most of it - still one squeak left in a similar position to yours.
01-24-2013, 04:45 AM | #7 |
56
Rep 1,255
Happy to report its sorted!
I tried WD in various places and the squeek continued.... in the end a little squirt around the buckle area mechanism and its gone |
