Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > My Diy Wheel Bearing Install Has Left Me With Another Problem!!!
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      12-30-2012, 08:44 AM   #1
curtisk70
curtisk70's Avatar
Drives: 2007 e90 328xi
So after I had some help installing a new rear wheel bearing on my 07' 328xi the proverbial ABS, brake, & 4x4 lghts all came on. If I remember correctly, these lights came on immediately when the car was started which I am hoping means the bearing was not put in backwards. I did much research including having the dealer run the diagnostic which came back as a bad wheel speed sensor. I found it hard to believe that some how it was damaged during the bearing install because the sensor removal/install seemed so simplistic (just a hex bolt and the sensor slides into the opening).... I did remove again and cleaned just as precaution but to no avail. I got the part & hope to install the new sensor today.
Has anyone had this happen to them after a bearing install? Could we have messed something up with the axle or created another problem elsewhere triggering the sensor??? I am skeptical replacing the sensor will resolve my issue but remain hopeful. I feel like I maybe chasing the issue...
      12-30-2012, 11:07 AM   #2
Red_Bean_Bun
62
Drives: E92
Nope. Probably a coincidence ....
      12-30-2012, 01:04 PM   #3
curtisk70
curtisk70's Avatar
So I installed the new wheel speed sensor with no resolve... errrrrrr!
      12-30-2012, 01:46 PM   #4
Juiced46
74
Drives: 03 Turbo Cobra, 2011 335xi
You put the bearing in backwards. It can be installed either way, however there is only one correct way. There is a magnetic pickup inside of the bearing only on one side. It will set wheel speed sensor faults because the sensor cannot pick up the trigger wheel due to it being in backwards. Unfortunately you will be installing another bearing.
      12-30-2012, 02:30 PM   #5
J-Spec Dan
ALL RIGHTY THEN
J-Spec Dan's Avatar
Drives: 12 STX Advance
in my case, i had to replace a front hub & wheel assembly earlier this year and the DSC, ABS, DTC lights went off after i drove around outside the garage for a little bit. maybe less than a tenth of a mile. it's like it has to recalibrate itself.
BMW CCA Member 483866
      12-30-2012, 05:27 PM   #6
sammy_0559
sammy_0559's Avatar
Drives: 335i
2008 E93 335i  [3.66]
What codes did you get if you don't mind me asking
      12-30-2012, 07:15 PM   #7
J-Spec Dan
ALL RIGHTY THEN
J-Spec Dan's Avatar
sorry man, i didn't pull codes. best of luck to you.
      12-30-2012, 08:53 PM   #8
sammy_0559
sammy_0559's Avatar
Drives: 335i
damn
thanks anyways.
LOL
      12-30-2012, 09:03 PM   #9
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
+1. Same thing happened to me. 2nd time is much easier as the bearing is not going to be stuck as much.
      12-30-2012, 11:07 PM   #10
hugus311
Titanium silver + Sport + Premium
hugus311's Avatar
Drives: 2006 330i (E90)
Are there any markings to avoid the same mistake. ALS any pics would help
      12-31-2012, 09:19 AM   #11
dassub
dassub's Avatar
60
Drives: '14 328xi sport line
I had those lights come on due to an aging battery a few months ago.
      12-31-2012, 04:36 PM   #12
StealYourFace
Drives: F30 328i M 6mt, E36 M3
I am trying to figure out the exact same thing.
Replaced the driver side- abs/dcs/cruise control all kuput. I figured the abs sens was bad because I had to give it a pretty good whack to get it off the hub. No biggie I figure.
Drove the car for a day and determined the driver side was just as bad. Didn't have the time or energy to do it so I had my mechanic do the job. Guess what- The speedo stopped working. OK, figured both ABS senors were bad, got two new ones from bmw, put on the car and the all the problems still exist no abs/tc/speedo.
So in my mind the only thing left is that both the one I put in and the one my mechanic put in went in backwards. One side is orange and one is black, I assumed that the black side was the side with the magnet or whatever the abs sensor communicates with.
Fucking frustrating.
      12-31-2012, 07:21 PM   #13
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
The bearing has one side that is black. I think that side is mounted inward. Don't hold me to that as I don't have the Bentley in front of me .
      01-03-2013, 09:44 AM   #14
curtisk70
curtisk70's Avatar
Thank you guys for the all the input.... I found a mechanic that says he will try to salvage the new bearing I put in and switch it around. He also mentioned that since we did not have the bearing pressed in it may not be "snug" enough which is tripping the sensor.
Either way hopefully this will resolve all issues... I will post the results after I get it done for those of you experiencing the same.
      01-03-2013, 07:18 PM   #15
Juiced46
74
Thats possible to, if you didnt press it in all the way the sensor will not pick it up.
If you didnt press the bearing in, how did you get it in?
      01-10-2013, 06:07 AM   #16
StealYourFace
OP did you get this resolved?
      01-10-2013, 08:07 AM   #17
curtisk70
curtisk70's Avatar
My car is in the shop today. I will post what happens later...
2007 328xi | 235/35/R19 | 6speed | Alpine White
      01-12-2013, 09:04 AM   #18
E36graduate
E36graduate's Avatar
58
Drives: 2013 335i M-Sport 6MT
I did both of my front wheel bearings and I believe the sensors would be easily damaged if you are not careful.
Try a battery reset...unplug battery for a little bit?
2008 335xi - 6MT - BMS JB4 G5i - BMS DCI - BMS OCC - BMS WW Meth - Spec Stage 2+ - Spec SMFW - 19" MVR Magnum's - KW V1's - TMS 12.5+20mm Spacers
      01-12-2013, 12:48 PM   #19
gm325xi
8
Drives: 325XI
I had the same problem when I did my wheel bearing. It was the ABS speed sensor for me. they are VERY VERY delicate and are commonly damaged during wheel bearing jobs, even if you did remove it you may have shocked it from banging in/out the wheel bearing.
      01-13-2013, 02:12 PM   #20
F31-340i
F31-340i's Avatar
United Kingdom
156
Drives: BMW 340i Touring
Hi, how did the lights come on - randomly during a drive, or when starting up?
I have had the ABS/DSC/speedo blank fault around 3 times - always when cruising on motorway after an hour of driving in the wet. I have also had the battery warning light a couple of times on separate occasions. Restarting the car makes it dissappear and it doesn't return.
From what I read a weak battery might be causing this, but not sure due to it occuring after a period of driving....
The link to very wet weather may also suggest a sensor issue, but then again it is a bit random and not frequent, so maybe a temperamental ECU after being warmed up by the engine....?
340i F31
      01-14-2013, 10:32 AM   #21
curtisk70
curtisk70's Avatar
RESOLVE!!!!!
So after all that I found the wheel bearing that was installed was the incorrect bearing! Ordered it from a reputable auto parts store in the metro Cincinnati area but it was not to spec. It fit however both sides were black not black & orange...
      07-18-2018, 11:44 AM   #22
dbjb
I sweat pheromones
dbjb's Avatar
203
Drives: e92 335i, retired SLK55
Did you ever figure this out? I just ran into the same problem with my rear left sensor and F A G bearing. Shop did the work. I verified Red Seal out. I even changed my sensor. Suffering the same ABS light as you. Really don't want to waste time swapping another bearing. Then again, hate driving with error lights.
Hopeful you found a solution.
Let me know. Thanks in advance!
