M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      12-29-2012, 07:10 PM   #1
ImpetuousRacer
ImpetuousRacer's Avatar
Drives: 2017 Tesla Model X P100D
2013 BMW M5  [0.00]
How do I install BMW Performance Pedals and Foot Rest?
Ok, I received in the mail today. They are the OEM BMW Performance pedals.
Brake looks easy. Heat up rubber with heat gun or hair dryer, slide off, and then heat rubber of new pedal, slide on, then screw on aluminum cover.
Foot rest. It has just 2 way tape. Do I just stick on right over existing foot rest? Or do I need to remove the old one first somehow?
Gas Pedal. Again, mainly 2-way tape. Do I just stick on to existing pedal, drill 2 holes into the existing pedal (What size bit?), and screw in?
Thanks for the help. Should be easy, just want to make sure I do everything correctly.
      01-01-2013, 05:18 AM   #2
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
I hope this helps you.
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      01-03-2013, 02:55 PM   #3
ImpetuousRacer
2013 BMW M5  [0.00]
Exactly what I needed. Thanks so much!
      01-04-2013, 03:58 AM   #4
johntomferg
Drives: Formerly drove a 13 F10 M5
The adhesive tape develops its full adhesive
strength after approx. 24 hours.
That is a long time to set with your foot pressed against the pedal...
Can we get some pics after you finish your work?
