Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Need advice
      12-29-2012, 06:22 PM   #1
dsimoes1
14
Drives: Bmw 325i Sport package
Need advice
I bought miguiars fine cut cleaner. Was wondering when I should use it? I have bad swirls and scratches on my car. Should I use that then swirl remover then wax?
      12-29-2012, 07:13 PM   #2
psnt1ol
psnt1ol's Avatar
31
Drives: e90
you should Wash -> Decontaminate (De-ironize, Clay) -> Corrections (defects removal)-> Polish -> Protection (wax/sealant).
How are you doing this? by hand or by machine?
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
      12-29-2012, 07:25 PM   #3
dsimoes1
14
By porter cable 7424xp.
      12-30-2012, 12:40 PM   #4
psnt1ol
psnt1ol's Avatar
31
Drives: e90
I don't know how bad your car is but I would recommend you use the following.
Wash, De-Iron and Clay, Menzerna SIP (IS1500) on LC white pad then finish down with Menzerna SF4000 on LC Black pad. IPA wipe down then proceed to wax/sealant.
or a more aggressive approach
Wash, De-Iron and Clay, Meguiars D300 on MF pad (speed 4) then finish down with SF4000. IPA wipe down then proceed to wax/sealant.
If you must use the product you have, you could try this.
Wash->De-Iron and Clay->swirl remover->fine cut cleaner->wax/sealant.
      12-30-2012, 01:23 PM   #5
dsimoes1
14
Thank you! You answered my weird question. Also I have turtle wax rubbing compound. Should I use that first then everything else after?
      12-30-2012, 05:02 PM   #6
psnt1ol
psnt1ol's Avatar
31
Drives: e90
I wouldn't use it at all..... Just skip it.
Keep this in mind, I believe the Meg fine cut cleaner was originally designed for the Rotary so your result will greatly be determine by your technique with the PC.
Which pads will you be using??? and what size?
      12-30-2012, 10:15 PM   #7
dsimoes1
14
I will be using miguiars cutting pad (dark red) and its 6.5inch
      12-31-2012, 01:02 AM   #8
psnt1ol
psnt1ol's Avatar
31
Drives: e90
I am assuming you have the yellow and the beige as well. I would do a test spot (16" x 16") first prior to buffing out the whole car to dial-in your process. Start with the yellow pad with the swirl remover (6-8 sectional passes with slow arm movement and firm pressure). wipe down and inspect. If the swirls marks are gone then you move to the next step (Polishing). If not then swap the pad to the Burgundy and try again. Inspect then move to next step (polishing) if the marks are gone.
If your process works on the 16"x 16" area then it should work everywhere on the car. If it doesn't then you either have to re-examine your technique, use a more aggressive approach, or a combination of both.
From my experience, a smaller pad works better on the PC. The bigger pad has a tendency to bog the machine down when pressure is apply (surface friction) which in-turn will lessen the correction power of the products and the polisher dramatically.
Good Luck!!!
      01-03-2013, 02:05 PM   #9
SHEEDI
Drives: 2009 335i - Sport PKG
2009 BMW 335i  [8.50]
Threads like this without pics are useless, we can not give you advice untill we see the pics
      01-03-2013, 06:50 PM   #10
Detailed Image
Detailed Image's Avatar
Drives: Detailed by Detailed Image
He's on the right track above. Our detailing guide can provide more information about these steps along with our Ask A Professional Detailer Blog. If you need any other advice please let us know.
Greg @ DI
