Winter Wheel Fitment Question
12-28-2012, 05:23 PM | #1 |
Rep 77
I keep searching but can't find the answer anywhere. Looking for winter wheels on Craigslist and ran into a good pair but don't know if they'll fit. It's a square setup with the wheels being 17 x 7.5 ET40 and tires are 205/50R17. Would they fit a E90 335i LCI??
12-28-2012, 05:54 PM | #2 |
79
Rep 197
Drives: M2
I don't believe the 335i can take 17" wheels, they won't clear the brake callipers.
12-28-2012, 09:06 PM | #3 | |
2031
Rep 2,672
The best thing would be to buy a used set from e9x. GL |
12-28-2012, 09:55 PM | #4 |
96
Rep 1,592
Drives: 2011 335d, M-Sport
Your best bet would be to ask the owner if he/she is ok with a test fit. I doubt you would have problems with most 17s, but you never know. I run 17s in wintertime and they have more than enough clearance. I would probably lean toward 225s though in an ideal world (driving-style dependent) unless you plan to only use the tires in the snow.
12-29-2012, 12:11 AM | #5 |
163
Rep 2,823
205/50/17 has almost the same diameter than 225/45/17. Only 0.098 inch difference.
But, i doubt those will clear the brakes, because the wheel is so narrow and has so high offset. Also it would look stupid, because wheels would be so deep in the wheel wells.
12-29-2012, 10:47 AM | #7 |
170
Rep 1,843
I think the 157s are 17x8 ET37 so OP's specs are not far off. That would be a great setup for heavy snow. However as others have said the only way to know that they would fit would be to test fit because of the caliper clearance issues - unless you know the mfgr. and model of the wheels and tire rack happens to sell them.
12-29-2012, 11:13 AM | #8 | |
163
Rep 2,823
Tyre itself would be better in the snow, because its narrower. I have 17x8 et 20 with 225/45/17 square setup on my pre-lci and going to add 10mm spacer to rear.Lci wont need the spacer ,because it has wider rear track. Here is pictures of my winter setup. http://www.e90post.com/forums/showpo...9&postcount=29
12-31-2012, 10:39 AM | #9 |
Moderator
369
Rep 4,745
Unfortunately there is nothing in the wheel specs that will tell you for sure if a given wheel will clear the brake caliper as the spoke design itself comes into play. If you find a 17X7.5" wheel that clears, you can use 205/50R17 or 225/45R17. If the wheel ends up being a 17X8, stick with 225/45R17.
Winter http://www.tirerack.com/a.jsp?a=AH8&...nter/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
12-31-2012, 04:51 PM | #10 |
68
Rep 1,432
I have this combo except the offset being 35. 17 inch wheels need to be test fitted to be sure they clear the brakes. Some poor designs don't.
