ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      08-15-2007, 11:25 PM   #1
soeharyo
lettuce
Drives: 2003 BMW Z4 3.0i
subwoofers
I am thinking of adding some woofers in the trunk of my Z4.
please share your thoughts as well as recommendations and experiences you have about subwoofers and amps
tia
      08-16-2007, 07:29 PM   #2
FloridaBoy
FloridaBoy's Avatar
19
Drives: 2005 Z4 3.oi
In the trunk, good gosh, THEN where would you put every other item you have to carry? There is so little storage on the car now...
2005 3.0i, Black Sapphire, SMG, Navigation, Heated leather, iPod w/Dice, Carver Subs, Sport, Foamless SG, 3M Clear Bra, Sirius, 18 inch 107's
      08-16-2007, 10:12 PM   #3
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
The Z4 wasn't exactly designed to be a hauler so it seems reasonable to use that space if you dont normally use it anyways. However of course if you fill your trunk on a regular basis then that would be a different case.
I haven't personally put any sort of aftermarket sound system in the cars I've owned but I did help my friend install two 10" rockford fosgate subs in his trunk and it went pretty smoothly, lots of wiring to be done and I dont particularly care for added bass but to each their own. One good piece of advice is absolutely bolt down your sub box. My friends although it weighs a good 40-50 lbs it has still fallen over more times then necessary. Lastly, it's like adding a small child to your trunk the weight will probably be noticeable.
      08-16-2007, 11:35 PM   #4
rabman5
Drives: none
2015 BMW M4  [0.00]
Ever thought about upgrading the two behind your seats? Might be easier with better results.
      08-17-2007, 02:59 PM   #5
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
That will be a future project of mine when I get to changing out the seats for some better buckets...
I have a Pioneer amp and Pioneer shallow mount 10" subwoofer to replace the woofers behind the seats. 3" depth so mounting should be too big a problem.
I plan on fibreglassing a box back there... or something... I'll worry about it when I get to it... in the meantime the sub and amp are collecting dust.
      08-17-2007, 04:38 PM   #6
FloridaBoy
FloridaBoy's Avatar
19
Honestly, the Carver subs that come with the premium system are plenty for me. I can only take so much boom-boom.
      08-17-2007, 10:10 PM   #7
rabman5
Drives: none
2015 BMW M4  [0.00]
There is a noticable improvement in the sound of my '07 ///M from my old '04 3.0. In the old car I actually had trouble hearing clarity and details at highway speed with the top down. I intended to upgrade the sound system on the M, but i don't need to. It sounds great.:rocks:
      09-04-2007, 01:41 PM   #8
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
does anyone have a wiring diagram for the "HI-FI" amp? not carver
want to put a sub in the trunk using truck box. thanks
2022 GLE 53 Coupe
      11-19-2007, 09:33 AM   #9
Hawkeye
Hawkeye's Avatar
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
One of my subs must be blown or something because my distortion is off the charts, even at normal listening levels.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      11-19-2007, 03:01 PM   #10
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
I am highly considering it, i just need my parents not to hate me for doing it.
Ian
      11-19-2007, 09:59 PM   #11
nyczyang27
nyczyang27's Avatar
Drives: z4 3.0si / 328xi
+1
2007 Z4 3.0si Step/Premium/Xenon/HeatedSeats/AutoTop/M6Wheels
2007 328xi Step/Premium/Sport/Xenon
      12-11-2007, 03:04 PM   #12
nate96
44
Drives: TI Silver 06 Z4 Coupe
I added the subs from my old vehicle in to the hatch. They were 2-10" MB Quarts with a 1000 Watt RMS amp. So a fair size box. I was more or less just trying to see how much of an improvement there would be in sound, then make a box for a single 10. Although the sound improvement was very noticable. It took so much away from space in the back. Even if I decided to go with a solo 10, I did not think the trade off was worth it. I played with the bass level enough to be satisfactory for now with the stock system.
zpost
