XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      12-19-2012, 09:54 PM   #1
x5lover7777
Drives: 2010 x5m
engine light after dp/tune
had dp and ecu tune with o2 off, now i have check light, read code as u0100: lost counnunication with engine control module/powertrain control module "a" and p0171: system is too lean,, i double check all wire and vacume hose and etc,,, any suggestion?
      12-20-2012, 03:05 PM   #2
RaTeD ///M
32
Drives: 2K13 M5
Who did your tune?
22 BMW M5 CS on order for August Production
20 BMW M5 Competition stage 1.5....
09 Zenith R GTR CP 4.4 Stroked CP tuned.....
      12-26-2012, 12:00 PM   #3
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Your tuner should be able to tune that stuff out. With these mods I would recommend a dyno tune. Its worth your time and money, trust me. They will straighten out your AFR so your not running too rich or too lean.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold
      01-16-2013, 12:52 AM   #4
Brian@MWP
Drives: BMW
Go right back to the shop who tuned your car. If all you did was a dp and tune you should be ok. A friend of mine has an x6 dp, eisenmann muffler and ESS tune since he bought it new and it now has 35k and no problems at all! Its a BEAST
      01-16-2013, 07:17 AM   #5
x5lover7777
Drives: 2010 x5m
spend so many hours search about this issue and went to few shops to get fix(got rip off ) i got tune and dp from aa, looks like there are gas leak between turbo and dp. after i installed new gaskets longft % drop. still bank 1 is bit high, i think i might need new dp, clamp and gasket again for passger side.
Search this Thread:
Advanced Search
xbimmers
