Coby Wheel
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Wheels and Tires > VMR Wheels | VB3's...More Finishes in Stock
      08-15-2007, 03:15 PM   #1
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Our shipment has come in and we have our standard finishes back in stock.
We currently have hyperblack, limited fitments of gunmetal, and super silver in stock!
Wheels: VMR VB3
Tires: General Exclaim UHP
Size: 19x8.5 +40 w/ 235/35/19 Fronts
19x9.5 +30 w/ 265/30/19 Rears
Fits: Will fit E90 (E92 will need 19x9.5 +45)
Price: $1679
Price includes BMW centercaps, mounting, balancing, and shipping to anywhere in the continental US.
For additional tire selections, we can get anything from tirerack, so just PM for more information/pricing!
      08-20-2007, 01:10 PM   #2
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
ALL PM's replied!
      08-20-2007, 02:39 PM   #3
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
When are vendors going to stock something other than et30 rears for e92? et30 will NOT work on a lowered e92.
      08-21-2007, 03:36 PM   #4
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+30 on E92 will work.
Depending on the brand of tire, some 265's are wider than others. Most will work with stock suspension, however if the car is lowered, then it becomes a little more difficult. On the wide 265's, if it rubs on a lowered car, users should try adding just a tad of negative camber to get rid of any rubbing issues.
      08-22-2007, 04:05 PM   #5
SGP335i
SGP335i's Avatar
Drives: 2007 335i E92 Jet Blk
Do you have a package deal for tires other than generals. Goodyears perhaps?
      08-23-2007, 01:18 PM   #6
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
If interested in different tire brands PM me for pricing.
      09-20-2007, 01:51 PM   #7
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
up
      11-09-2007, 06:46 PM   #8
jumpingjz
jumpingjz's Avatar
Drives: 2007 328i Coupe
Hi,
WOuld you please PM me price on CSL (VB3) 18" stagger application for E92 in hyperblack finished wheel/tire package? Thank you.
JZ
      11-09-2007, 08:45 PM   #9
Sideshow
269
Drives: M2C
I didn't see it listed, so I guess TPMS are not included......
F87 M2C
E92 335i
E36 M3
      11-19-2007, 04:23 PM   #10
nsanbyker
nsanbyker's Avatar
Drives: 6 speed
Will this setup work on a xi without any problems?
      11-19-2007, 05:01 PM   #11
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
More proof that +30 rear offset DOES work on a lowered e92 without fender rolling, and yep thats my exact set up I am running (mentioned above)
      11-19-2007, 05:04 PM   #12
tek818
136
Drives: 2020 X3M Competition
2018 M3 ZCP  [9.50]
+1 ... E92 on H&R sport with Hyperblack CSLs ET30 rear. NO ROLLING and NO RUBBING
      11-19-2007, 05:49 PM   #13
nsanbyker
nsanbyker's Avatar
Drives: 6 speed
Thanks for the reply brandonanix. I thought I remember reading on one of the forums about keeping the sizes of the front and rear wheels on a xi close to equal so as not to screw up the awd and sensors. I could be wrong. Are you using any spacers? Your car looks really clean and very mean. Good work.
      11-19-2007, 07:17 PM   #14
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
You can post an anecdote, but I've done the math.
http://www.e90post.com/forums/showthread.php?t=79560
The reason you're not having a problem is that the maximum drop on H&R sport springs is roughly equal to the minimum drop on Bilstein or KW coilovers.
From here: http://www.e90post.com/forums/showthread.php?t=613
1.3" / 1.2"
--> H&R Sport Springs (part # 50490)
Compared to the most common coil overs sold:
KW Variant 2 coilovers (part # 15220032) -- Lowering range--> Front: 1.2-2.3" Rear: 0.9-2.1"
Bilstein B16 PSS9 coilover (part # GM5-C051) -- Lowering range--> 30-50mm (30mm = 1.18")
IMO, people with e92's on coil overs should be wary of ET30 rears unless they are committed to doing what it takes to make a more aggressive look work.
I'm kinda perplexed by VMR's comments in this thread versus what they said in the linked thread back in August:
Originally Posted by VMRWheels View Post
+30 is the best choice on a stock suspension E92, and while we've had lowered customers without complaints of rubbing, it appears more and more are getting rubbing issues. As time goes on its beginning to appear that a +33 would be a good offset that should fit on a lowered E92 without rubbing, but even then its still speculation.
However, it still stands that a 9.5" +30 w/ 265 tire on E92 is not a definite WILL rub case, but when you lower it it will depend on each persons setup.
When lowering the car with aftermarket wheels and wide tires, not all fitments are going to be perfect. If the user wants to have specific wheels and tires on their car, and they've just taken the next step to lower the car, then they're going to do what it takes to make it fit, be it rolling fenders or alignment adjustments.
Right now there aren't many +33 offset wheels available, so the best choices are +30 or a +45 w/12mm spacer.
EDIT: btw, your car looks great!
-Hegemony
Pics
      11-19-2007, 07:41 PM   #15
Flea7
Flea7's Avatar
Drives: E92 M3 6MT/F48 X1/F430/F12
2016 X1  [0.00]
2008 E92 M3  [0.00]
2005 Ferrari F430  [0.00]
2014 Ferrari F12 Be ...  [10.00]
a little off the topic but...it looks like he needs a camber kit for the rear? That might also effect the clearance.
      11-20-2007, 12:07 AM   #16
PAKMAN
PAKMAN's Avatar
North Korea
360
Drives: 2011 E92 M3
2011 BMW E92 M3  [9.50]
2006 e90 330i  [5.50]
pm on just the rims
stock car
      11-26-2007, 05:59 PM   #17
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
If you see the original post date of this thread, and dates of other posts, you'll notice it was before Hegemony's thread, and that whole E92 fitment discussion took place.
It is now known that +33 is ideal, and +30 is prone to rubbing on E92. We will not make any false claims to customers in order to sell wheels, and will no longer recommend a +30 for your average E92 owner. But for those who are willing to make the modifications necessary to make a +30 work on their vehicle, we will sell them the +30 rears.
For E90 the same fitment as always applies, +40 up front, and +30 rear work like a charm.
      11-27-2007, 08:47 AM   #18
Hegemony
Fast Like Tiger
Hegemony's Avatar
Drives: 07 M Coupe
Awesome guys!
-Hegemony
Pics
