Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > LED Resistor Question
      12-16-2012, 12:50 PM   #1
gdgraham
gdgraham's Avatar
Drives: 2007 328i Coupe
I installed rear LED turn signals and they threw an error until the first time I used them in each direction, then it goes away. Today I installed front LED turn signals and they threw errors and hyper flashed so I installed 25 Watt 6.5 ohm load resistors. I installed the passenger side first and it worked perfectly. Then, I installed the driver side resistor and it works perfectly. However, after I installed the driver side the passenger side now throws an error and hyper flashes. My question is do I need to install larger resistors or should I install a pair on the rear now too? I’m getting an error code of 119 which is the front passenger turn signal. Any advice is much appreciated. By the way, I’m on my fourth pair of PY24W because I haven’t found a pair that was error free yet so that isn’t looking like an option.
      12-16-2012, 02:44 PM   #2
Chrispy650
Chrispy650's Avatar
Drives: E92 LCI
Easiest way is to just code them out. No resistors needed and you won't have any flickering, hyperflashing, or errors.
      12-16-2012, 02:50 PM   #3
gdgraham
gdgraham's Avatar
I'd really like to do that but I can't find anyone within 200 miles of me with the capability and I'm not ready to try and tackle that on my own yet.
      12-17-2012, 07:17 PM   #4
gdgraham
gdgraham's Avatar
Installed a pair on the rear and it didn’t help. Then I removed it and installed two resistors on the front passenger side. After installing two resistors the error would go away and then come back every couple minutes for however long I drove the car. Anyone have any ideas?
      12-17-2012, 07:55 PM   #5
07e92
Drives: 07 335i
yeah... unfortunately, best way is to code them out, 06/07 is very picky on the LEDs, I installed PY24W on my 07, and it still throws error msg even the seller claims the bulb is canbus and error free.
