F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > alignment needed?
Studio RSR
      12-15-2012, 02:43 PM   #1
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
alignment needed?
Just went from stock 18 setup to 19" wheels with et32 offset. 19x8.5 et32 235/35/19 front and 19x9.5 et32 rear 265/30/19 rear. No change in suspension. Should I do alignment? Thanks for advice.
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      12-15-2012, 02:56 PM   #2
Renus
Renus's Avatar
28
Drives: E92 335i
Wow, ET32 would be outer than the fender, am I right? Somebody said you need do alignment, somebody said no, but if you are intended to change suspension in coming future, better do it after your new suspension has installed.
      12-15-2012, 04:05 PM   #3
PeterM
17
Drives: bmw 335i
No you dont, unless you installed some sort of suspension on the car.
2013 EB2 335i 6MT
      12-15-2012, 06:46 PM   #4
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
Yes it sticks out but no rubbing. I will eventually drop it but it will be slight drop. When its dropped I have read on this forum that it will fill fender. Don't know how true it is. I love the wheels but they are aggressive.
      12-15-2012, 11:54 PM   #5
Renus
Renus's Avatar
28
Drives: E92 335i
Do you know how to roll your fender? Maybe can help a bit but it's all depending on how much your wheel stick out. On my ex-E92 335, I have rolled it but still I found the edge of fender too thick, I asked garage to hammer it flat. But in F30, the edge is thin, so you just need to roll it to a bit wider.
      12-16-2012, 01:32 AM   #6
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
I am going to see if its possible to shave 3 mm of the rears. iND had BBS with 19x9.5 et35 rear and it looks perfect with H&R. If I can do this it would be perfect solution
Search this Thread:
Advanced Search
f30post
