Wheel balancing machine question
12-13-2012, 05:55 PM | #1 |
DIYER
614
Rep 5,521
Took my brand new "Concept ones" with less than 100 mile on them to make sure they where balanced perfectly (thought a weight popped off) and when on the balancing machine they where not 100% running true. The balancing machine is the type that has a cone that is inserted into the hub and it spins and you can see they where not perfectly straight....could this be the machine doing this or is the bore/hub off a bit? 1 rim was perfectly true....other 3 had a bit of movement
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
12-13-2012, 08:11 PM | #2 |
BimmerPost Supporting Vendor
2040
Rep 25,989
Depending on the machine, they're able to do a 'run-out' test to determine whether the wheel is bent or warped.
VMR|Wheels | 714.442.7916 |
12-13-2012, 08:30 PM | #3 |
DIYER
614
Rep 5,521
I know this machine was a older one (same one that did my car when I was 16 lol!!)...the wheel goes on then a cone shaped arm goes into the hub, they drop this plastic thing over the tire and it starts spinning (best explanation I can give.). Just hard to believe a bad wheel of this quality...never hit anything ever lol!! Have you had a set of wheels like this....probably not (great wheels, by buddy as 2 pairs lol)....trying to see if this is common, can't find anything on it.
