The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - HomeLink in the rain sensor
      08-14-2007, 12:54 PM   #1
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
Thumbs up DIY - HomeLink in the rain sensor
Name:  DIY-homelink-335i Step-A.jpg
You need :
Your current homelink remote with the code programmed for you garage or buy a new one for 25 $
A tiny switch - 50 cents
2 x 8 inch wires
Name:  DIY-homelink-335i Step-B.jpg
Open the remote. You don’t need the cover anymore.
Name:  DIY-homelink-335i Step-C.jpg
Weld the two wires to remote’s switch and connect them to the new switch.
Name:  DIY-homelink-335i Step-D.jpg
Open the cover of the rain sensor
Tape the wires inside the cover
The switch will be positioned on the top, between the two parts of the cover
But back the battery (if you want, you can use the 12 V source coming from the car )
Wrap your remote with something to ovoid any electrical contact.
Name:  DIY-homelink-335i Step-E.jpg
But back the cover of the rain sensor in the car, insert the remote in the remaining space and close.
Name:  DIY-homelink-335i Step-F.jpg
Only the switch remain outside of the cover, then just push the button and that’s it!
This DIY is completely reversible.
335i E92 / Sideral-Gray/ Coral Red / Aluminium / 6M / Winter Pkg / DIY HomeLink
K.I.S.S ...Keep it simple stupid
      08-14-2007, 01:12 PM   #2
phantom330
phantom330's Avatar
18
Drives: e93 335i
I guess I'm confused on what this mod actually does..........is this for garage door opening or cars not equipped with homelink?
      08-14-2007, 01:18 PM   #3
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
Yes this mod is for garage door opening for car not equipped with homelink. Sorry for my english, I speak usually french!
      08-15-2007, 09:57 AM   #4
pokerface
pokerface's Avatar
430
Drives: F25 X3 N20 / F80 ZCP
Sorry - I'm having trouble visualizing - where did you install the button?
      08-15-2007, 10:27 AM   #5
FrankoQ
Deny everything
FrankoQ's Avatar
Drives: 2006 330i; 2015 X6, S1000RR
2015 BMW X6  [0.00]
2006 330i  [0.00]
could you post a pic a bit more far away from the rear view mirror so we can
see how the switch looks like?
Very nice mod btw.
I need a drink
      08-15-2007, 10:33 AM   #6
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
I will take a picture and post it later. The swith is located on the top of the rain sensor, so it's really invisible. But you can put it in another place.
      08-15-2007, 06:27 PM   #7
nyc3r
nyc3r's Avatar
Drives: E90
Very nice mod btw.
+1, Guess this should be added to the master diy list.
From what I can tell he put it up in his rear view mirror top center of the windshield. The button is on the bottom of the rain sensor.
How did you remove the cover? Just pull hard? I like the mod, just that it's a bit involved just to change the battery.
      08-15-2007, 09:17 PM   #8
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
The swith is located just under the rubber between the rain sensor and the roof. The wires keep the swithc in place, but you can use glue. As I said before we can connect to power of the remote to the 12 V of the car, This mod is available with the DIY - Clown nose blinking LED. But if you are leasing the car, it's better to change to battery once a year!
http://www.e90post.com/forums/showthread.php?t=25207
To open the rain sensor, just use a credit car to separate the two parts. It's very easy also to close.
Name:  DIY-homelink-335i Step-G.jpg
      08-15-2007, 09:20 PM   #9
esbezee92
esbezee92's Avatar
Drives: Montego 328i Coupe
maybe a stupid question but this doesn't affect the actual rain sensor does it?
also, i have a gate and garage, you think its possible to fit two of those things in there?
      08-15-2007, 09:43 PM   #10
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
Depending of the size of your two remote, maybe you can put them togethe inside, open the rain sensor and try it before. There's no effect on the rain sensor. Mine's work perfectly!
      08-16-2007, 07:05 AM   #11
FrankoQ
Deny everything
FrankoQ's Avatar
2015 BMW X6  [0.00]
2006 330i  [0.00]
Thanks for the additional pic.
Great mod and DIY.
I need a drink
      10-06-2007, 07:03 PM   #12
uter
BMW nerd
uter's Avatar
83
Drives: E9, E28, E31, G87 M2
I really like this. Touble is, when look at the back side of my garage door opener's insides, it isn't so obvious as to where to solder the new wires.
      10-06-2007, 09:33 PM   #13
alanchan
alanchan's Avatar
72
Drives: 2006 323i
very nice thanks
but what is the spec of the switch?
323i, Arctic metallic , Cream beige leatherette interior , Titanium matt trim , Premium , Auto , 18" style 189 sport wheels , 335i bumper + kidney grills, CF pillars, Chrome window trim package , LCI halogen.
      10-09-2007, 12:10 AM   #14
oel
oel's Avatar
Hong Kong
28
Drives: 09' E90 335i, 13' E92 M3
2009 E90 335i  [0.00]
Where can I find a switch like that?
All I can find locally is too big to fit there
      10-09-2007, 01:34 PM   #15
Kiss335i
Kiss335i's Avatar
7
Drives: 335i E92
The small switch or any other swith can be found at a specilazed spare electronic store, probably at Radio Shack. If you don't fin one, try to get one from an old electronic device like the reset switch of an old computer.
The new switch needs to be connected with the wires to the connections of the actual remote switch.
      12-01-2007, 04:58 PM   #16
YBLegalE92
YBLegalE92's Avatar
Drives: 08 E92 White
wow. thats very claver!! good thats my other mod thank you!!
