Please help. Will these fit?
12-08-2012, 03:18 PM | #1 |
38
Rep 475
http://atlanta.craigslist.org/atl/pts/3426616428.html
Hankook Ventus tires 255 35 275 30 He is not sure of the offsets, thinks rear or both are +20. He had them on a E46 M3 and a E36 with no rolling or cutting. I have a 06 E90 with sport suspension. I do not want to lower more, roll, or cut. Thanks in advance! |
12-08-2012, 09:07 PM | #6 | |
144
Rep 4,501
12-09-2012, 01:35 AM | #8 |
453
Rep 2,973
Not sure how he had the same wheel on an E36 and an E46 M3. The correct offset for an E46 definitely won't fit on an E36. I had an E36 and E46 factory wheels had a bad offset for the E36. The offset for an E46 is also wrong for an E90.
That being said, without knowing the offset, it's good not to buy. A good offset for a 19" wheel on an E90 that is not aggressive and doesn't require a fender roll is 19x8.5 front, 19x9.5 rear both with +35. You should be able to fit a 235/35 up front and a 265/30 in the rear. Depending on the tire you can get some 275/30 tires to fit. All this with no rolling of the fenders and not rubbing. I have a sedan, but a coupe should be similar, if that is what you have. I'm running Foregestar F14s in the fitment I described with 235/35 up front and a 275/30 in the rear. I'm running Falkan 722 all weather high performance. I have sport suspension. No issues at all, even with five in the car. |
12-09-2012, 09:54 AM | #9 |
38
Rep 475
Thanks! Going to save all of that so I know when i buy. Whenever I get new wheels I will more thank likely run Hankook Ventus V12 tires. I have had really good luck with Hankook.
12-09-2012, 04:19 PM | #11 |
38
Rep 475
19x8.5 et40 and 19x9.5 et45? I'm sorry I have tried to understand offsets and just can't wrap my head around it. Looking at some LM reps, they are my favorite.
12-09-2012, 04:24 PM | #12 |
168
Rep 3,900
Those will fit but wont look as well because of high offset. I have 19x10 rears et 24 w/ a 265 and im thinking about putting a 15mm spacer on them. Im rolled and dropped.
12-09-2012, 04:38 PM | #13 | |
144
Rep 4,501
12-09-2012, 04:49 PM | #14 |
38
Rep 475
Ok I'll ask this. I have read threads and there is currently another but here's the true ordeal.
I want some 19" LM Reps Hankook Ventus V12 tires I do not want to lower, roll, or cut fenders. I do not have a lot of money and trying to stay around $1500 or lower. What are my best choices? |
12-09-2012, 07:48 PM | #15 | |
205
Rep 2,770
Drives: E92 328i, E92 M3
12-12-2012, 07:56 PM | #16 | |
BimmerPost Supporting Vendor
2042
Rep 25,989
255's won't fit in the front without fender work.
VMR|Wheels | 714.442.7916 |
12-13-2012, 03:53 PM | #17 |
38
Rep 475
I knew anything M3 would be low so that's about where I decided I wasn't going to purchase.
I am also looking into some 20x8.5 et37 and 20x10 et33 LM reps. I know people don't like 20s but I think the LMs look great in 20s plus they are a couple hundred cheaper. I want the Hankook V12 tires. Would 235 35 20 and 255 30 20 work? On tirerack it doesn't show they have a 265 30 |
