12-05-2012, 01:10 PM | #1 |
20
Rep 307
Front license plate holder on M sport - ?
Currently I live in Italy and here you have to have a front plate...I think all of Europe does. Anyway, for those that live in a state that you have to have a front plate have you found a good one that doesn't require any drilling? Thanks!
12-05-2012, 04:02 PM | #2 |
47
Rep 420
Yes, I currently use the U.S. Mills front license bracket and am very pleased, it uses the front tow hook as an attachment for the license plate.
Although, it would work for you it might not be ideal, I believe U.S. license plates are taller than European license plates so, if you used this solution you may not be able to affix it properly. If you're curious look at this link. Perhaps, this is what you're looking for. Good luck. |
12-06-2012, 04:30 AM | #4 |
20
Rep 307
Thanks for the link, looks that would work. We do have different plates here but I can get a long or two small ones because not all US spec cars can use the longer one so it shoudl work.
For the double tape..Id be worried it would fall off or get stolen. |
