Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 11 bmw 323i winter rim questions
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      12-05-2012, 07:54 AM   #1
erth
Drives: 2011 bmw 323i
good morning, i am having an issue with a tire shop concerning winter rims. i have asked for 16" rims with michelin rubber. i setup the appointment, he put on the tires, and i drove away with the calipers scrapping the new rims. drove back in and had them removed. now, he is telling me that they can't find specifics for the 323i.
hopefully someone can help me out. what rim/wheel information do i need to give to get the correct steel rim on my car?
thanks.
      12-05-2012, 08:37 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Your factory comes with 16" alloy. The 16" steel rims can be used (maybe rare to find)
Size: 16" x 7", 5 Lug, 120mm Bolt Pattern, 31mm Offset
For BMW part #
http://www.bavauto.com/se1.asp?dept_id=323
thanks.
      12-05-2012, 08:47 AM   #3
erth
my 2011 323i came with 17" 225 45 r17 91h.
so my issue is going to a 16" steel rim for winter tires. i believe the 16" rubber is less expensive and will work better in winter driving.
is the offset of 31mm the important part of the equation?
      12-05-2012, 08:52 AM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
the offset is important as to how the rims sit in relation to the brake caliper.
Ask your shop to see what offset you had previously. He may be using some sort of universal steel rims, thinking it would not matter.
      12-05-2012, 08:54 AM   #5
erth
will do, thanks for your help.
