BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Got my JBD. Install tips?
      12-04-2012, 10:34 AM   #1
torifile
10
Drives: 335d
I don't want to clutter up the forum with threads that aren't relevant or duplicates but this forum is kinda slow anyway so....
I got my JBD today. I'm planning on installing it later. Any gotchas or caveats I should watch out for? I've been trying to find out how to remove the engine cover because that seems like the most challenging part of the mod but everything I find talks about the 335i which is different from our engines.
Should I leave it at the default setting or should I turn it up before trying it out?
Any tips/advice would be appreciated.
      12-04-2012, 10:43 AM   #2
Sweattdogg
15
Drives: 08 e90 M3/09 e90 335d/13 f10M5
Engine cover is no problem with a hex tool. You have to remove a little plastic piece from the stock harness. From there plug and play. Put the unit somewhere out of the way with a zip tie. I put my unit somewhere I could easily adjust it.
I tried 100% and got codes. Dropped it down 5% or so per run, until no more codes. I"m guessing that was about 85%. Mine is off the car now for the winter. Figure I don't need extra torque in the snow.
      12-04-2012, 11:13 AM   #3
sohcpunk
sohcpunk's Avatar
Drives: 2011 335d
2011 335d  [0.00]
Make sure you zip tie the plugs together. If some how engine vibration disconnects those plugs, your car will be in big trouble.
      12-04-2012, 12:32 PM   #4
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
Plug it and go. Seriously, make sure the sensors connector and JBDs snaps with a little clip. Zip tie the JBD so it sits secure, preferably on the cold side of the engine.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      12-04-2012, 03:01 PM   #5
torifile
10
Drives: 335d
All installed. I got the cover off without too much of a problem, but I could not get the rear left screw back in. Not sure what is going on there. It just won't get threaded for some reason. Not a big deal as the other 4 went back in just fine.
I zipped tied it and I think it's all good. Do I need to be concerned about heat near the wire connectors? They're just sitting on the engine block there. Seems like a less than ideal place for them. And where the heck is the adjustment dial? I couldn't find it anywhere.
      12-04-2012, 04:10 PM   #6
Ryballz
Drives: 335d
My cover was missing the rear screw already, I guess the dealer must have removed it at some point and couldn't get it back in either
      12-04-2012, 04:26 PM   #7
DSB335d
1322
Drives: '11 335d DSB/oyster&black/navi
You need a small screwdriver to open the JBD. It's a little potentiometer inside. You can adjust it however you like and then turn it down if you get any codes. Hopefully you have a scan tool or the tool that BMS sells.
      12-04-2012, 06:13 PM   #8
torifile
10
Drives: 335d
I was trying to be on my best behavior with my wife in the car tonight since I'm just getting used to the extra power. I thought I was doing a pretty good job but my wife still said "why are you driving so fast tonight?" I guess it works.
      12-04-2012, 09:21 PM   #9
FormerRotor
FormerRotor's Avatar
96
Drives: 2011 335d, M-Sport
Lol it definitely works.
I noticed that my dealer cross threaded the rear left torx screw for the engine cover when I got it back from service a while ago. Make sure you have the screw at an angle as this is how it is mounted (follow the angle of the indentation on the left). If it doesn't go in, it's not the end of the world, especially if you aren't getting any funky rattles.
Enjoy the JBD!
My Picture Threads (Oldest to Newest): 1 2 3
Join BMW CCA! (Use my link and I get credit )
      12-04-2012, 09:33 PM   #10
torifile
10
Drives: 335d
Enjoy the JBD!
That was it. I needed to angle the screw.
How to I adjust the power? Where's the dial?
      12-04-2012, 10:06 PM   #11
FormerRotor
96
Great; glad it worked.
Remove the two Phillips head screws on the box and you will see the (small blue & white) potentiometer referenced in the above post by DSB. Use a small flathead screwdriver to turn the dial to your preferred setting & enjoy. Make sure that the ECU is asleep before adjusting (this may be an unecessary precaution, but I prefer erring on the side of caution).
      12-07-2012, 09:00 AM   #12
torifile
10
Drives: 335d
I got a Service indicator today. Should I be concerned? My service mileage notice says 1800. Is that typical to get the service notice so soon? I have the code reader but I haven't used it yet.
      12-07-2012, 09:48 AM   #13
torifile
10
Drives: 335d
I read the fault codes but I'm having trouble translating them. Can anyone help?
      12-07-2012, 09:43 PM   #14
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
Can tool is too hard to read. Borrow a Bav Tech reader from someone.
      12-07-2012, 10:32 PM   #15
torifile
10
Drives: 335d
I emailed Burger and they said that the codes were probably unrelated and said I should clear them and see if they come back. If they do, I should pull the JBD and clear them again and see. I cleared them and my car still says Service at startup (I verified that there are no codes) so maybe my car is due?
They also said that they couldn't figure out what the codes mean either, so I'm not sure what that means...
      12-08-2012, 01:53 AM   #16
FormerRotor
96
Does it say to service or are you getting an SES light?
      12-08-2012, 04:13 AM   #17
DSB335d
1322
How many miles on your car? Maybe it's due for an inspection.
      12-08-2012, 06:55 AM   #18
torifile
10
Drives: 335d
Service.
I've got 41000k miles. Inspection not due til 4/2013. I checked the OBC to see the dates of various services but nothing is soon.
Maybe I'm just making something out of nothing? It might have been just a coincidence that my service notice appeared a couple of days after installing the JBD. I'll just check the codes periodically and troubleshoot from there. But why can't I figure out what those codes mean?
      12-09-2012, 06:07 AM   #19
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
What codes are you getting?
      12-12-2012, 09:20 PM   #20
torifile
10
Drives: 335d
The video up above shows them. I cleared them and they have not come back though my car still says "Service" (not the SES light).
      12-15-2012, 06:30 PM   #21
corbin
Drives: 335d 2010 & x5d 2012
any update?
      12-17-2012, 07:30 PM   #22
torifile
10
Drives: 335d
After clearing the codes, they didn't come back. The service light is still on but I suspect it has to do with my brakes. My indie mechanic who knows his stuff said that's what it was and he's very good.
That said, I'm going to sell this mod and put the money towards a sub from Musicar NW. I think I'll appreciate it much more. Here's my for sale post if anyone's interested: http://www.e90post.com/forums/showthread.php?t=781921
