F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW f30 328i coilover DIY
proTUNING Freaks
      11-28-2012, 12:05 PM   #1
slmdgee
Usofstance
Drives: 328I 6SPD
Will update this thread when I receive my Bc coils from Bc. Ordered November 15 so it should be here any day!
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      12-23-2012, 07:47 AM   #2
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Update? Can you list the tools needed for the install of springs? I want to make sure I have all of the proper size sockets/wrenches on hand so I don't have to run to the hardware store mid-install.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      12-23-2012, 09:05 AM   #3
slmdgee
Usofstance
Drives: 328I 6SPD
Woops totally forgot!! Honestly 1/2,13mm,15mm,18mm,20,21,22 I believe those are the right sizes. Also you deff need a breaker bar.
      12-23-2012, 10:31 AM   #4
mikew2069
mikew2069's Avatar
413
Cool, thanks! So you really need 20, 21, AND 22?? .. Also do you need a e14 torx?
BM3/H&R/Borla
      12-23-2012, 02:14 PM   #5
slmdgee
Usofstance
Drives: 328I 6SPD
pretty sure 21!! is a must its good to have those and you need torx for the top hat on the shock tower. For only the front shocks.
      12-26-2012, 01:26 PM   #6
s1k0ne
87
Drives: ..
so no pictures regarding the DIY?
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      12-26-2012, 02:24 PM   #7
slmdgee
Usofstance
Drives: 328I 6SPD
i was in a rush!!! i did the coils in 2hrs in my garage!
      01-26-2013, 11:30 PM   #8
Casualvic
26
Drives: 328i xdrive
What a fucken waste of internet ink!!!!! Where is the diy on installing springs???
      01-27-2013, 07:08 AM   #9
mikew2069
mikew2069's Avatar
413
I'll be intalling springs by next weekend at the latest. Maybe Wed. I'm considering doing an nice DIY but it will add an hour or so to the job so we shall see..
BM3/H&R/Borla
      01-27-2013, 07:26 AM   #10
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
lol calm down, this whole thread probably takes a few hundred kb
I would love a DIY guide too, im done overpaying for everything car related
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      01-27-2013, 12:46 PM   #11
mikew2069
mikew2069's Avatar
413
Hey man, hopefully you can help me out. I just took my wheels off to look at everything. Mainly to make sure I have all the tools I need and there aren't any surprises.
The front looks straight forward - which is strange b/c that's normally the harder axle. The rear had a bunch of stuff going on that I haven't seen but I'm pretty sure I know what to do.
Please see the attached picture. This is the bottom of the shock on the driver's side and the pic is taken from the rear of the car. My question is, did you undo the bolt on the right? The other side has an etorx bolt and its kind of blocked by a plastic shield. I just want to make sure that this is the proper bolt to take out before I go and buy an etorx kit. What did you do about that plastic shield?
IMG_9864 - With Notes by mikew2069, on Flickr
Cheers!
BM3/H&R/Borla
      01-27-2013, 02:08 PM   #12
Casualvic
26
Drives: 328i xdrive
Ya my bad!! The cursing was not needed! But good grief! Why in the world would you start a threat and not even have the springs installed when it was started??!!
      01-27-2013, 06:05 PM   #13
slmdgee
Usofstance
Drives: 328I 6SPD
Yeah man thats exactly how you do it! you gotta pull like a straight screw driver in by the plastic so u have enough clearance. It's easy if you got power tools.
      01-28-2013, 06:32 AM   #14
mikew2069
mikew2069's Avatar
413
Cool, thanks. Do you have to take the 21mm bolt on the left out also so you can push the control arm down or will it push down with just the bolt on the right removed?
BM3/H&R/Borla
      01-28-2013, 12:02 PM   #15
slmdgee
Usofstance
Drives: 328I 6SPD
One bolt is a nut That stay there. I cant really explain just go out and do it.
      01-28-2013, 01:10 PM   #16
mikew2069
mikew2069's Avatar
413
Cool, I know I can figure it out. Was just hoping to not reinvent the wheel
BM3/H&R/Borla
      01-28-2013, 02:23 PM   #17
slmdgee
Usofstance
Drives: 328I 6SPD
Yeah should be good`
      01-29-2013, 06:55 PM   #18
mikew2069
mikew2069's Avatar
413
One more question before I get started this weekend. On the front, did you take the entire front strut assembly out? I read a DIY on the e90 board and the guy did NOT take the entire strut out. He just kind of pulled the top out of the fender which I thought was very strange.
BM3/H&R/Borla
      01-29-2013, 07:27 PM   #19
slmdgee
Usofstance
Drives: 328I 6SPD
Okay well i had to take the whole shock out and re use the shock tower so i can install that piece on my bc coilovers if that helps you out.. My car is rwd .
      01-29-2013, 07:33 PM   #20
mikew2069
mikew2069's Avatar
413
Oh yea, obviously you'd have to take it all out since you were doing coilovers and not just springs. Forgot about that
BM3/H&R/Borla
      01-29-2013, 11:01 PM   #21
Sephanite
57
Drives: BMW Z4
If you are doing coilovers, the front should be the 3 bolts on top, bolt behind the brake caliper, knock the lower arm holding the shock, remove shock that is connected to springs, put in coilovers with springs, loosely tighten top 3 bolts, lower arm up onto shock (use hydraulic jack to help push the rotor up) and tighten all bolts.
back pretty much same process just that the spring is separate. i just pushed down on the arm and yanked it out. the lowered springs went in easily
f30post
