XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
View Poll Results: Would you be interested in a multi function gauge for your E7X?
Yes 9 81.82%
No 2 18.18%
Voters: 11. You may not vote on this poll
      11-26-2012, 03:37 PM   #1
bulldog_yyc
bulldog_yyc's Avatar
130
Drives: GT3RS
Interest in RIXX Gauge for E7X
I have approached P3 cars to potentially make some gauges for the x5 and x6 models (35i, 50i and ///M). I had their gauge on my E90 and was very happy.
I created this thread to gauge the level of interest for other folks who may be interested. Please vote yes or no if you would be interested.
Not sure on price (yes this is important) but for comparison purposes, the F10 model is $389, $409 for the E9X model so pricing could be in that neighborhood (not confirmed).
http://www.p3cars.com/catalog/e90
Plug and Play install
Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector.
Boost/Vacuum Display
High resolution boost/vacuum display showing actual manifold boost, Read Boost/Vaccum via diag port directly, no tap required.
Multiple Gauge Displays
Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Peak Recall & Run Record
Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs
Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu
Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
      11-27-2012, 03:52 PM   #2
ndabunka
Drives: 2012 X5 35d Sport Black/Black
Voted NO because...
projected price point is too high. If it was $200 or (maybe) as much as $250 then it could be a nice feature but at or close to $500, NO WAY!
      11-27-2012, 04:07 PM   #3
bulldog_yyc
130
Drives: GT3RS
The vendor has to be incented to make the product. For reference, the competition (for the x6 anyways) makes a centre dash mounted gauge and it costs about 1400 euro. So relatively speaking ,$500 is not a bad deal is it, even if that is the final price (not yet confirmed - but will probably depend on the level of interest).
Also, for about $150-$200, you can get a mechanical boost gauge. The Rixx gauge has an electronic boost/vac reading, plus temp, timing, EGT's (etc etc) built in. Thats where I see the value, beyond its obvious advantage in aesthetics.
      11-27-2012, 07:55 PM   #4
ndabunka
I've always found this way of thinking as...short sighted. If you could sell 200 units @ $200/each you would have MORE "incentive" than if you sold 7 (the # of "I would buys in the poll above at the time of this post". Which would provide more incentive to a manufacturer?
I am also a member of a motorcycle forum where a LOT of vendors are. One vendor has offered a "keyless start" modification for non-Harley bikes for about 2 years now and up until ast week he was asking $489/unit. I honestly don't think he has sold more than ten in that time. We started a "group buy" for them and he agreed to drop the price based on the number of interested buyers. He got 30 buyers @ $249/unit. Seems like he figured it out & if he can do it, then other developers could do the same thing, right?
And just in the event that you might want to verify my reference, here it is...
http://www.thevog.net/forum/thread/1...nition/page_1/
      11-28-2012, 07:07 AM   #5
bulldog_yyc
130
Drives: GT3RS
thats fine, thanks for your interest
      11-28-2012, 11:20 AM   #6
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Very cool... keep me posted with this through some pms. I would be interested if we could put some kind of group buy together.
How easy is the install, is there a diy? I don't trust anyone else working on my truck. If I fuck up its on me.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold
      11-28-2012, 12:57 PM   #7
bulldog_yyc
130
Drives: GT3RS
the install is pretty easy - but will ultimately depend on where the data is acquired, ie directly from the engine components (DV) or from the CAN bus network (from the ODB2 port), which is easier.
      12-05-2012, 04:22 PM   #8
bulldog_yyc
130
Drives: GT3RS
ttt
      12-10-2012, 02:18 PM   #9
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
25
Drives: '08 M Coupe
A lot better solution just came out by these guys
http://www.awron-shop.de/bmw-displaysysteme
X6 is not listed yet on the shop I got confirmation that they just finished the product.
      12-10-2012, 04:06 PM   #10
bulldog_yyc
130
Drives: GT3RS
for how much though?
      12-11-2012, 04:30 AM   #11
SmartBastard
Stupid as shit
Austria
25
Drives: '08 M Coupe
1k EUR
Here's the email if anyone is interested:
Der Preis für das X6 Display liegt bei 990,- EUR inkl. MwSt. Es werden folgende Messwerte ausgegeben:
Kühlwassertemperatur
Motoröltemperatur (über externen, mitgelieferten Sensor)
Geschwindigkeit (inkl. Vmax)
Längs- und Querbeschleunigung
Beschleunigungsmessung 0-100 / 0-200 km/h
Drehmoment
Leistung in PS
Diagrammdarstellung von PS und Drehmoment
Ladedruck
Da das X6-Display noch sehr neu ist, gibt es noch keine Fotos davon. Es ist perfekt in den Lüftungsschacht integriert und verfügt im Gegansatz zu unseren anderdn Displays über Schlitze für den Luftauslass. Somit ist die Leistung der Klimaanlage kaum beeinträchtigt.
Es ist noch nicht in unserem Shop verfügbar, aber ich nehme gerne hre Bestellung per Email auf. Sollten Sie über eine Umsatzsteuer-ID verfügen, liefern wir natürlich steuerfrei nach Österreich.
Viele Grüße,
Armin Dörr
Dipl.-Kfm.
Armin Dörr
Marketing-Manager
AWRON automotive
Robert Sop
Olschewskibogen 5
80935 München
www.awron.de
www.awron-shop.de
Tel +49-89-96165300
Fax +49-89-96165301
Mobil +49-177-2438670
Email armin.doerr@awron.de
      12-16-2012, 01:49 AM   #12
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
31
Drives: X5M & X5 35d
Did this ever go anywhere?
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      12-16-2012, 07:55 AM   #13
bulldog_yyc
130
Drives: GT3RS
still working on it
      01-04-2013, 03:49 PM   #14
dreamalaska
Drives: 2013 X6 3.5i
I would be interested...
      06-25-2013, 11:22 PM   #15
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Sorry to bump such an old thread but has there been any movement on this project? I had a p3cars gauge in my F30 335 and would love to get one for my E70.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
xbimmers
