Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Buring Oil 1qt/3k
      11-19-2012, 07:12 AM   #1
diddlkiss
Drives: 2010 335i E90 Lci N54
2015 F33 435i  [0.00]
2015 F82 M4  [0.00]
2011 F10 535i  [0.00]
2010 BMW E90 LCI 335i  [7.50]
Buring Oil 1qt/3k
Hey
I think my car buring oil,
2010 335 sedan,38k miles,
more oil in my FMIC and chargige,
Mod:
procede v5
meth
ar cat-less downpipe
afe DCI
forge FMIC and BOV
I use motul 300v and mobil 1 0w-40
and change oil 6k miles(BMW service 10,000km)
I think my turbo buring oil,
but in China
BMW sale warranty only 2years and unlimited miles.
Any adivse
thanks so much.
      11-19-2012, 08:26 AM   #2
ajm8127
ajm8127's Avatar
Drives: '07 335i
You should check the PCV tubing that connects to the rear turbo intake duct. If you find oil in there (which I imagine you will) then maybe it is time to use a oil catch can.
This picture shows a catch can and the arrows point to aftermarket tubing, but notice the point where it connects to the intake duct. See how it has the wires running out? Pull the PCV tubing connection off and check for oil here.
I also use about 1 qt every 3k miles. Or are you talking 3k kilometers?
      11-19-2012, 08:36 AM   #3
diddlkiss
2015 F82 M4  [0.00]
its 3,000 miles(4800km)
I get my RB turbo next week,if the stock turbo buring oil,I think the RB turbo dont buring maybe....
      11-19-2012, 09:47 AM   #4
ajm8127
ajm8127's Avatar
Drives: '07 335i
If there is oil in the PCV tube and the intake duct, then the oil is not coming from your turbos, it is coming from blow by gasses.
      11-19-2012, 09:51 AM   #5
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
You should not be running 0W oil, the recommended weights are 5W-30 or 5W-40
You should also not run racing oil but rather a high performance street application. If you like motul switch to 8100 Xcess 5W-40
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      11-19-2012, 10:18 AM   #6
ajm8127
ajm8127's Avatar
Drives: '07 335i
Mobil 0w-40 is BMW approved for the N54 (LL-01). It's a very common oil to use because of its availability. Motul 300v is a better oil that Xcess 8100, although it is probably unnecessary for the street.
      11-19-2012, 02:21 PM   #7
nikitino25
nikitino25's Avatar
Drives: '07 E92 335i
I noticed that after 1500 miles since my last oil change, the level has dropped one bar on the display. Does anyone know how much oil that one bar equates to? Essentially i'm one bar down from full, how much oil have I burned?
      11-19-2012, 02:25 PM   #8
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
0,25 ltr
      11-19-2012, 02:32 PM   #9
AK 335i
AK 335i's Avatar
48
Drives: black 335i E90
its not how much oil youre burning, but how many BTU's youre burning that matters
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
      11-19-2012, 04:23 PM   #10
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Maybe you're leaking oil and not burning it. Check valve cover gasket, PCV connections and oil filter housing for leaks.
E90 LCI N54 6AT
      11-19-2012, 11:55 PM   #11
diddlkiss
2015 F82 M4  [0.00]
I d check every cover,but its will be fine.
But I can see more oil in my FMIC and charage and BOV,
and the exhaust pipe so black.
so I think I need a cancath maybe.
because my PVC is not work...
I do a valve Wash in last week,
the valve is very dirty.
