BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Boost issue
      11-15-2012, 02:14 PM   #1
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
Boost issue
I have been FBO for about 14,000 miles now. Car has 103,000 miles.
Recently, my car hasn't felt as quick as it used to be. Wastegate rattle is rediculous and I feel like my turbos just aren't pushing as hard as they used to, I used to hit 16psi easy with JB4, I have been doing WOT runs and my car is only hitting 12-13 psi, this is with little humidity and 63 degree ambient temps, I know it isn't a boost leak as I just fixed one...could my turbos be going out and has anyone else experienced this loss in boost?
I do blow some white smoke out of the exhaust every once in a while but other than that and the wastegate rattle, I have no other noises or weird things happening with the turbos as far as I know
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash
768 whp 695 ft lbs - E85 - 32PSI
      11-15-2012, 04:27 PM   #2
AK 335i
AK 335i's Avatar
48
Drives: black 335i E90
when you are hitting 12/13 psi, what are you targeting, have you logged map1 or 2 just to see if you hit targets?
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
      11-15-2012, 04:49 PM   #3
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
I'm map 5 right now, I will put it on map 1 or 2 and see if I hit target boost
      11-15-2012, 11:18 PM   #4
Wedge1967
Drives: '07 e92 AT Sport Montego Blue
I had to replace all of my vacuum lines recently because they were all cracked. Started out boost would only hit 16, then 12, then 8 and at WOT it would drop even more to 4. Eventually I lost all boost. Good luck
      11-16-2012, 12:47 PM   #5
Redrkt503
Redrkt503's Avatar
31
Drives: E92 335is
How much was it for all the lines
