11-14-2012, 04:29 PM | #1 |
40
Rep 282
AFE intake for N20
Just thought I would share some info. I installed my AFE intake and can feel a difference. No CEL's. engine noise remains close to stock with a subtle increase in pressure release from the turbo. Off the line performance is better and the power remains constant up until the high 5's from what I can tell. Will update later on with long terms thoughts and fuel economy feedback.
11-14-2012, 06:41 PM | #2 |
20
Rep 371
Thanks for the feedback! Mine is sitting in the living room waiting for my car to get here...along with the aFe exhaust, intake scoop and BMS Stage 1.
Can you hear the intake from inside while driving? |
11-14-2012, 09:07 PM | #3 |
40
Rep 282
I'm waiting on my BMS to arrive as well. Let me me know how the downpipe turns out. You can hear it but it's not very deep. The increase in sound seems the same at all RPM's. i am pleased. My only concern is the increased airflow will cause the computer to pump more fuel resulting in a loss of mpg. If that is the case I believe the ECU will adjust over time but I am no expert.
11-14-2012, 11:34 PM | #6 | |
20
Rep 371
11-15-2012, 08:35 AM | #8 |
Rep 74
Matt, which air filter did you go with, the Pro Dry S or the Pro 5 R? I'm leaning towards the dry filter to eliminate risk of fouling the MAF with oil from the 5 R (though if it's never over oiled, it should be OK). What I don't know is which filter is more effective at catching particles, probably neither one is as effective as the stock paper filter.
TIA,
-Ed
2013 F30 328i M Sport 2008 Lotus Exige S240 |
11-15-2012, 10:31 AM | #9 |
14
Rep 300
every intake manufacturer promises numbers like that
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
11-15-2012, 11:00 AM | #10 | |
40
Rep 282
11-15-2012, 11:01 AM | #11 |
193
Rep 3,780
True, I also am always skeptical about intake power claims.
I had an Carbonio on my CC, claimed 15hp at the crank. My butt dyno wanted to concur. All I know is it had to make some more power because the clutch slipped when I had software+intake, the next day when I removed the intake, the clutch held the power no problem-no slipping.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
11-15-2012, 11:29 AM | #12 | |
14
Rep 300
intakes can improve performance in two ways; IAT and flow. If the stock airbox location is providing IAT's higher than 6-10 degrees above ambient, there's room for improvement; if not, an intake is useless. That brings up flow.....nobody tells you this spec (except perhaps Banks Power). You'd have to nearly double the output power of most modern turbo cars to exceed the flow capabilities of a stock airbox. I think the reasons you guys think the car is faster with an intake alone is that your wallets are lighter, thereby improving performance.
11-15-2012, 06:06 PM | #13 | |
Just some guy
49
Rep 1,531
^ what he said. Once u get a downpipe. full exhaust. change out your turbos to bigger turbos and increase the amount of boost youre running, etc. Then you can put on an aftermarket intake and see some real gains. Til then its a nice little mod that makes 3hp. it looks "Cool" inside your engine bay and makes a nice little woooshhhh noise with a tiny bit of growl when you hit the gas.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
11-16-2012, 08:38 AM | #16 | |
14
Rep 300
You'd be surprised what a good panel filter in the stock airbox can do......50-75% of the benefits of an intake at 10% of the cost. I put an AEM panel filter in my SRT8 and got lean codes so it flows more air as well. I can monitor IATs via the LCD screen.....6-8 degrees F over ambient.....pretty darned good. <--- has bought dedicated intakes for quite a few cars but gotten rid of them unless a tune was involved.
11-17-2012, 05:00 PM | #17 | |
7
Rep 93
Congrat's on a great sounding intake for a lot of money. I would say it felt faster on my butt dyno 2000 also! |
11-17-2012, 07:22 PM | #19 |
7
Rep 93
Absolutely incorrect statement. Add an intake to a stock car, and you will see no/neglible gains, proven on Dyno's from a non seller of intakes. Add an intake that sees higher IAT temps, and you will see lower HP on the same dyno. I will have to pull up the episode of Mythbusters that tookquite a few cars, stock to full aftermarket turbo with engine work, and they proved an intake was neglible overall. The built car with a ton of mods and larger turbo was still barely showing a decent HP gain from a stock intake to an aftermarket one, Intakes, overall, by themselves do nothing but sound and butt dyno improvements. With other mods, with a very small increase in HP, they are neglible, but, when you talk about doubling the stock power, then you are needing more air into that forced induction engine, you will then see some improvements.
11-17-2012, 09:03 PM | #20 |
20
Rep 371
^ Your right, my Evo that made power on the dyno with an intake must have been a dream.
Also are you saying the dyno sheet aFe posted showing gains with their intake is not real? |
11-18-2012, 12:35 PM | #21 |
Rep 121
I'm a bit curious as to why the two dyno runs shown on the aFe dyno chart are a week apart...
For me to be convinced of any power gains, I'd want to see back-to back dyno runs from customers (not from manufacturer or resellers). I remain skeptical. The chip tuners have shown that a more aggressive program will make more power with the stock intake, so clearly the stock intake is capable of flowing more air than required by the stock engine. I think it may be possible to improve upon the OEM design to provide more flow, but that's only helpful if the flow of the stock design is restrictive. I certainly wouldn't expect much if any gain on a stock or lightly-tuned vehicle. But I'm more than happy to be proven wrong, so let's see some dyno charts! |
11-18-2012, 02:03 PM | #22 |
161
Rep 342
Drives: 2019 BMW M760li
I agree that an open filter intake probably offers negligible power gains. The stock intake on most cars today are designed to be more than capable if equipped with a better filter element. But for turbo cars, especially those with increased boost levels, a higher flowing CAI or open filter intake should enhance throttle response and power delivery at highway speeds and top end quite a bit.
The 328 gets choked out as the speeds pick up, but the power still feels available. I would imagine with a ram scoop and open air intake, the performance at higher speeds would be better. |
