F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Vehicle height update
Extreme Powerhouse
      11-12-2012, 11:47 PM   #1
Drk280
Drk280's Avatar
Australia
22
Drives: 2012 F30
Just for some information, finally got a reply from BMW Australia and their reply was that all their RHD cars will be lower on the right suspension due to the car being designed for LHD and fuel + battery weight making the car lower on the drivers side here in RHD land. Suspension is unadjustable also. Up to a 3cm drop is acceptable.
Well that was a disappointing result, seeing as how the average Aussie male weighs around 130kg, the drop is unacceptable imo.
Going to go and see a suspension mechanic to see if they can raise the car to be level again.
      11-13-2012, 01:06 AM   #2
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
I just measured the height of my car from level ground to the top of the rear arch. Both sides sit at around 68.5 cms.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      11-13-2012, 01:17 AM   #3
MikeVictor
Australia
210
Drives: anything given a chance
I call bollocks to that.
      11-13-2012, 01:35 AM   #4
CKau
33
Drives: G01 X3 Xdrive30i M sport
Before you see the mechanic maybe reply to them and say you are getting an independent view on this from an accredited independent bmw shop. You will take the findings to the ACCC if they find an issue with your car.
So does it affect your handling? Could arguably be a safety issue.
I couldnt accept that.
      11-13-2012, 01:55 AM   #5
Drk280
Drk280's Avatar
Australia
22
Drives: 2012 F30
At the end of the email they said it does not affect the handling, sadly I cannot see how far the car sinks when I sit on it, gonna have to get someone from work around the same weight to see, will take a pic too from the rear so you can see what I mean.
      11-13-2012, 01:56 AM   #6
MarkyMarkOz
Australia
Drives: F30 328
I suspect that is at least 40kgs over the facts...
      11-13-2012, 02:09 AM   #7
MarkyMarkOz
Australia
Drives: F30 328
Australian Bureau of Stats ; "In 2007–08, the average Australian man was 176.0 cm tall, weighed 85.2 kg and had a waistline of 96.2 cm."
      11-13-2012, 04:54 AM   #8
David328M-Sport
Australia
101
Please cite references for your statement as I believe this to be a gross exaggeration.
Here's a good starting point as per MarkyMark's post above:
http://www.abs.gov.au/ausstats/abs@.....0Chapter22011
      11-13-2012, 06:14 AM   #9
Drk280
Drk280's Avatar
Australia
22
Drives: 2012 F30
Lol maybe I should have added "around here" at the end of that statement and by here I mean geographically where I am and not these forums.
f30post
