JB4, Catless DP's, 91 oct, 4000ft elevation, which map?
11-05-2012, 01:50 PM | #1 |
7
Rep 145
So I just installed catless downpipes over the weekend. I am running them with my JB4. I live in El Paso TX which is at 4000ft elevation and only has 91 octane fuel. So my question is, which map should I run? I was told that Map 5 (autotune) doesnt work good at my elevation, and Map 2 says it is for 93 octane. Should I stick to map 1? Any suggections? Thanks
07 e92 335i / SGM / CORAL / Aero Kit / JB4 / BMS DCI / VRSF 3" DP's / Eibach Pro-Kit
11-05-2012, 02:39 PM | #2 |
70
Rep 2,626
Start with map1, log and see how your car likes it then go from there
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
11-05-2012, 05:28 PM | #3 |
ex deus machina
124
Rep 968
Map 5 is not good when you constantly drive in different elevations, if your car never sees below 3K feet, you should be good on Map 5
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
11-05-2012, 10:14 PM | #5 | ||
7
Rep 145
http://www.e90post.com/forums/showthread.php?t=500597 Quote:
So far the car feels good on map 1. I just ordered the USB cable so I can run some logs and make sure my jb4 is updated
11-05-2012, 10:32 PM | #6 |
12
Rep 281
Drives: 2007 E92 335i
Map 5 will auto adjust. You may want to reset it if you come down the mountain or change fuel blends.
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS DPs | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
11-05-2012, 11:54 PM | #7 | |
Joint Chiefs of Staff
4919
Rep 115,980
Make sure to flash the latest firmware on your JB4 as well. Mike |
11-06-2012, 09:26 AM | #8 |
7
Rep 145
I just ordered the cable for my jb4 so as soon as it gets here I will do that. Thanks
