M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      11-04-2012, 09:04 AM   #1
bradone1
BMW Extraordinaire
Drives: 2019 X7 M Sport, 2015 M4 Vert
Which oil out of the 4 choices??
Hi Guys,
I was at the dealer yesterday buying all of my new ///M accessories and i asked about a quart of oil, they assured me that i was supposed to use the TWS 10W-60 which we all know is wrong. After about 2 hours of crazy searching i found out that the new Castrol German made oil that is LL01 approved is now called: Castrol Edge SPT 0W-30
My question is should i go with which of the following for the new M5? i am torn:
1) Genuine BMW High Performance 5W-30
2) Castrol Edge SPT LL01 approved 0W-30
3) Motul 8100 X-cess 5W-40
4) Redline 5W-30
All of these are LL01 approved except for the Redline oil
I live in Miami FL and i will push the car to the limits here and there, i probably wont track the car if only maybe a few times in its life.
Thoughts??
      11-04-2012, 09:24 AM   #2
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
In the manual it says you can use:
0W-30
0W-40
5W-30
5W-40
You might want to find out what (competent) BMW dealers use for the 1M, X5M, and X6M, since I believe they have the exact same oil spec as the M5. I'm reading that 5W-30 tends to be used in the US, but not sure about brand.
I'm not surprised that a dealer thought 10W-60 was needed, sadly. I just hope they'd notice the spec on the oil cap before actually putting that into someone's car....
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      11-04-2012, 09:43 AM   #3
mdernst
mdernst's Avatar
Drives: Tesla Model S
2013 BMW M5  [0.00]
Take your pick
BMW 5W-30 is what's in my M5 and that's what I'll continue to use. However, the attached file shows all approved oils for use in the S63T(U) engine.
Mike
      11-04-2012, 09:43 AM   #4
aus
Drives: Odysse
Just get the BMW oil.
Another option is Mobil 1 0W40, which is also LL01/ACEA3. But I burned oil with this vs not burning a drop I with the BMW oil in an N54 engine.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      11-04-2012, 09:44 AM   #5
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
557
Drives: 2014 911 Turbo S
Originally Posted by bradone1 View Post
Hi Guys,
4) Redline 5W-30
Thoughts??
I have a strong preference for 0W-30 myself. I think it provides better protection at start up and at both higher and lower temperatures.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      11-04-2012, 09:50 AM   #6
bobblehead
bobblehead's Avatar
256
Drives: warp speed
+1 on choice #2
      11-04-2012, 10:21 AM   #7
Mperial
Mperial's Avatar
Drives: 2016 M3, 2017 X1
Amazon sells #2 for about $7.50 a quart
http://www.amazon.com/Castrol-06244-...strol+Edge+SPT
      11-04-2012, 10:39 AM   #8
Rob///M5
Rob///M5's Avatar
76
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
BMW put 5w-30 during my service. Assume I need to continue using 5w-30 when topping off? Or can I use the Castrol 0w-30?
      11-04-2012, 03:06 PM   #9
Infamous///M5
Drives: E60 ///M5 - C43 AMG
What about royal purple ?
      11-04-2012, 03:36 PM   #10
stealth.pilot
Knight Commander
United Kingdom
557
They aren't BMW approved. Neither is AMSOIL.
If you want that sort of thing, you should get Pennzoil Platinum 5W-30 european blend. Bob the oil guy uses it.
The thing that bothers me about Castrol Edge is I have read multiple reviews saying it is a dirty oil. There is also a video on youtube comparing it to BMW Oil and the BMW oil seems cleaner. This a concern in an engine known to burn oil. You want an oil which produces little ash.
      11-04-2012, 08:25 PM   #11
bradone1
BMW Extraordinaire
I think that YouTube video test actually shows the bmw oil to be sludgy and the castrol holding up better?!?
      11-04-2012, 08:39 PM   #12
bobblehead
bobblehead's Avatar
256
Drives: warp speed
actually, if I may add ...
I doubt any of the M5 owners will do oil change once a year, therefore, I believe any brands oil (approved) will do.
I will change mine out every 6 months
      11-04-2012, 09:14 PM   #13
stealth.pilot
Knight Commander
United Kingdom
557
Yes that's what I do too. In the past I used to do every 4 months, but 6 months seems more sensible.
      11-05-2012, 12:46 PM   #14
Sharpie12
Drives: 2013 F10 M5 SG/SO
ill do mine every 5-7k miles with motul 5w40
2015 F10 M5 - AW/SO- Retired 2013 F10 M5 - SG/SO - Retired 2010 E60 M5 - Retired 2010 X6 50i - Retired
2006 E60 M5 - Retired 2004 E60 530i - Retired
      11-06-2012, 06:31 PM   #15
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Time or distance?
It seems to me the mileage based oil change is the more sensible method rather than a time based change interval? I'm not knowledgable about the chemical properties of oils, either petroleum based or synthetic, but I wouldn't think the oil breaks down while sitting in the oil pan over time. It's the wear and tear on the oil while lubricating moving parts that is the primary factor.
      11-22-2012, 07:44 AM   #16
bobblehead
bobblehead's Avatar
256
Drives: warp speed
For those in Europe ... here is a current offering on the Castrol Edge FST 0W40 5 L for 39.50 Euro. Not sure if this is a good deal or not.
http://www.schmiedmann.com/5_series/...ge3.htm#paging
      11-22-2012, 08:54 AM   #17
bradone1
BMW Extraordinaire
Just an update since I started this thread, I am very good friends with my dealer's shop foreman (bmw mechanic) and he ensured me to use the regular bmw high performance oil 5w-30 (in the silver bottle that they use for the regular 535i)
He said that he would highly recommend me paying for an additional oil change in between at 5k intervals if I am planning on keeping the car and i want to be in great shape
I will allow him to use the bmw oil even though i hear it can sludge earlier than Castrol, i mentioned this sludge factor and he said 'that's why I said to do it every 5k'
Lets see what happens, I'm not so sure I feel like showing up to my oil change appt with bags of my own castrol oil either...
      11-22-2012, 09:22 AM   #18
stealth.pilot
Knight Commander
United Kingdom
557
Which dealer do you use? I just did my break in service at the dealer.
I may go independent for off cycle oil changes and bring bags of 0W-30
      11-22-2012, 09:56 AM   #19
bradone1
BMW Extraordinaire
I'm at south, Braman is just too big and I know everyone at south. Michele is the mechanic I was speaking about, and Armando Cajigas is the SA
Which 0w-30 will you use??
      01-18-2013, 04:49 PM   #20
stealth.pilot
Knight Commander
United Kingdom
557
I'm thinking of making the switch to GC 0W-30 soon. How many quarts do I need? Should I just buy the oil on Amazon and then take it to your guy Armando?
      01-18-2013, 04:55 PM   #21
mindlessmark07
mindlessmark07's Avatar
47
Drives: 2013 F10 M5
#2 is my choice.
MindlessMark07
///2013 M5 Alpine White/Black,Orange County CA\\\
      01-18-2013, 05:32 PM   #22
bobblehead
bobblehead's Avatar
256
Drives: warp speed
http://f10.m5post.com/forums/showthread.php?t=755298
Search this Thread:
Advanced Search
