Racing Harness E90
08-05-2007, 04:05 PM | #1 |
75
Rep 1,288
Drives: 135i
Racing Harness E90
Hey Guys,
I have a 335xi Sedan and I just did my first autocross today. I had the problem that as soon as I'd take a turn I'd have to take my hand off the steering wheel cause my body would be flying to the side and had to brace myself with my elbow! Does anyone know if there are four point racing harnesses for the E90 Sedan? Preferably something removable.... Thanks, Dave
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
08-05-2007, 04:30 PM | #2 |
89
Rep 3,011
lookey lookey
http://www.sportscar-parts.com/sprbelts.htm or you could search "racing harness" racing harness
"Teach the ignorant. Ignore the stupid."
08-05-2007, 05:03 PM | #3 |
Rep 122
Try this:
Before you run, scoot your seat back a foot, put on your seatbelt, Pull the shoulder harness so that it's about crushing your lap, then yank the other direction to engage the inertial lock. Then move your seat back into driving position. You should be nice and snug, and the belt shouldn't loosen during your run. Cheap and easy. Worked fine for me yesterday. You might supplement this method with a CG Lock. Richard |
08-05-2007, 05:05 PM | #4 | |
143
Rep 6,333
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
08-05-2007, 05:15 PM | #5 |
75
Rep 1,288
Drives: 135i
rsjames, thanks! I was trying to do something like that but didn't think to move my seat. I guess I'm not used to the whole helmet thing and I had to move my seat for my head not to hit the roof. and 330iS....first time = car going EVERYWHERE. I was also running on stock runflats so I was loosing traction left and right....I was probably a bit (read extremely) heavy on the throttle too.
Chesmu, thanks too. I guess I forgot to do a search on the forum itself for once :-P
08-05-2007, 07:05 PM | #6 |
574
Rep 6,750
Member "cgnahc" showed me an innovative device that attaches to the existing safety belt that allows you to manually lock it. You may want to PM him and ask what the brand is.
Sparco makes rear harness bars for the E30 and E36, but not for the E46 or E90. |
08-05-2007, 09:09 PM | #7 | |
23
Rep 134
08-05-2007, 11:45 PM | #8 |
75
Rep 1,288
Drives: 135i
It was a Genesee Valley BMW CCA Autocross at MCC.
08-06-2007, 11:08 AM | #9 |
52
Rep 648
Buy a Schroth Profi II ASM four point harness ($265.00) and a Rallye End bolt On Kit (#01324) to attach to stock mounting locations. This is the only way to run a harness for now until Schroth releases a E90 snap in kit.
08-06-2007, 05:01 PM | #10 |
75
Rep 1,288
Drives: 135i
sg335: nice catch! Street legal too....damn....I'll definitely look into that combination, thanks a bunch
08-06-2007, 06:20 PM | #11 | |
19
Rep 313
Also if you like AutoX, you may love DE. It's a bit more expensive, but in my opinion you learn way more and really get to put your car through more types of situations.
335i Coupe: Crimson Red / Black
X3 3.0si: Alpine White / Sand Beige |
08-06-2007, 06:52 PM | #12 |
Rep 122
[QUOTE=longodj;1252499]rsjames, thanks! I was trying to do something like that but didn't think to move my seat. I guess I'm not used to the whole helmet thing and I had to move my seat for my head not to hit the roof. and 330iS....first time = car going EVERYWHERE. I was also running on stock runflats so I was loosing traction left and right....I was probably a bit (read extremely) heavy on the throttle too.
I'm surprised that you were losing traction that much with the AWD. I ran my first event with the car Saturday, and the peg leg was killing me. Part of the problem is the last car I had was AWD, so I had no traction problems at all. Yeah, I have to lay the seat back a little farther than I'd like to accommodate my helmet, and that makes my butt scoot forward. But the trick I described works pretty well. May try a CG lock next time. Richard |
08-06-2007, 07:33 PM | #13 | |
84
Rep 1,263
Need someone to install angle eye bulbs December 2018
08-21-2007, 08:35 PM | #14 |
580
Rep 3,547
I recommend the CG Lock for cars not equipped with a roll bar. Harnesses can be more of a danger then they do good if not properly set up with a roll bar. YES thats right I said a ROLL BAR ... harness bars are the devil and provide NO ROLL OVER PROTECTION. If you roll your car and your rocking harnesses unlike standard seat belts you will be locked in that up right position.
Not only that but with out a proper Roll Bar your mounting points for your shoulders will most likely be too low (as they will probly mount to the rear seat area) and can cause spinal compression in an accident. Also if your running 4 point harnesses your run the risk of submarining. Sorry Im just a safety nut ... if you look at my garage you'll see my old evo was big on safety for track days. For the BMW its too nice of a car to get nuts with with a roll bar or cage .... the CG LOCK will def help keep you in place and keeps all the safety of the stock restraint system. |
08-24-2007, 02:57 PM | #15 | |
Get a grip. Get Xdrive.
14
Rep 529
Drives: 330xi
2006 330xi current
08-24-2007, 05:39 PM | #16 | |
434
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
Car is now gone .... :-( |
08-24-2007, 05:49 PM | #17 | |
580
Rep 3,547
08-25-2007, 12:50 AM | #18 |
434
Rep 4,380
Tony is a good friend of mine.
08-27-2007, 07:08 AM | #19 | |
2148
Rep 10,176
Schroth says they "hope to have something by late 2007". I would up getting Schroth Rally 4 (bolt in) harnesses. The crappy thing about them is that you have to remove the bottom back seat cusion to use them, and you cannot put the cushion back, with the rear harnesses still attached, since the cushion fits very tightly. |
08-27-2007, 10:20 AM | #20 | |
434
Rep 4,380
08-27-2007, 12:03 PM | #21 |
50
Rep 1,137
Does this apply to the e9x? I did not experience that with my e46. On the bright side, think of the weight you would save!
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11 |
08-28-2007, 09:20 AM | #22 |
75
Rep 1,288
Drives: 135i
Hey guys, I got my CG Lock yesterday. Holy crap! I haven't tested on track yet obviously but just driving around town it feels completely different when it's on. I guess a lot of the problem I was having at the track was being thrown around having really heavy feet but I definitely won't have that problem anymore
