Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Removing Etchings - Need Advice
      10-30-2012, 05:00 PM   #1
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
Take a Look, here's what I'm working with. Also some haze going on with these panels. Talked to a painter and he advised that this could be removed (etchings and haziness) with a 3000 grit wetsand and polish. He was very hesitant to do any paint work to correct the problem.
      10-30-2012, 07:42 PM   #2
psnt1ol
psnt1ol's Avatar
31
Drives: e90
Try to polish it out with a DA first before sanding.
What type of equipment do you have? Polishes??? Pads????
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
      10-30-2012, 07:43 PM   #3
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
They look like water spot etchings; no need to wet sand (most likely) and definitely no need for respray. Use compound, then polish, then final polish.
      10-30-2012, 07:56 PM   #4
MStar
Drives: e92 M3
You dont need to wet sand that..not even use an agressive compound..
Light to medium duty compound and then polish should do it
      10-30-2012, 08:03 PM   #5
Bimmer Barney
1250
I have experience using an orbital, but not a DA. How about the haze? Is this a job best left to a professional?
2011.5 E90 M3 DCT ZCP Slicktop
      10-30-2012, 09:14 PM   #6
Kmf1207
Drives: E90 328i lci
The haze can be polished out with a m205 and a finishing pad. That combo might even work on the water marks (with a DA). These are not an uncommon occurrence and can easily be handled by a novice with the right technique.
      10-30-2012, 10:24 PM   #7
Bimmer Barney
1250
Thanks for the tips all. I'm going to head over to detailed image and get sorted with some products. Sounds like I can do this, rather than pay a professional, so I'll buy my own gear I'll post pics of the process and results.
      10-30-2012, 10:30 PM   #8
abhishriv
100
Drives: 2007 335i Coupe (Space grey)
this should be very easy for you.. like the others have said. a medium compound polish maybe paired up with the LC orange pad on a DA should tackle this.
      10-31-2012, 12:37 AM   #9
Bimmer Barney
1250
Order placed with DI Can't wait!
      11-08-2012, 09:08 PM   #10
Bimmer Barney
1250
I have finished the hood and fenders and the results are stunning. Pics to follow, but thanks for encouraging me to tackle this myself! Pads are now drying after being cleaned.
      11-11-2012, 08:06 PM   #11
Bimmer Barney
1250
Pictures as promised!
