BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Cobb 4.0 vs 4.1 stg1 st throttle
      10-29-2012, 09:42 AM   #1
gmazzu
19
Drives: 335 M-Sport X-Drive 6 speed
Does anyone know the difference between the 4.0 an 4.1 code for stg1 stock throttle? I have been running the 4.1 code and recently flipped back to 4.0 and the 4.0 is simply smoother. The dip in on the throttle is just smoother, part throttle and initial acceleration. Anyone have any ideas?
      10-29-2012, 10:05 AM   #2
JStang
JStang's Avatar
562
Drives: FDB M3 CS
What are your mods and what map are you running? Go to the following link and click on the Map Notes link next to your supporting mods.
http://www.cobbtuning.com/AccessPORT...maps/bmw/I8A0S
      10-29-2012, 10:15 AM   #3
gmazzu
19
100% stock, stage 1 agressive
      10-29-2012, 10:20 AM   #4
JStang
JStang's Avatar
562
Drives: FDB M3 CS
Map notes
https://static.cobbtuning.com/cobbtu...sPORT_v402.pdf
      10-29-2012, 10:26 AM   #5
gmazzu
19
Well the notes say very little, there is a dead spot in the pedal on initial tip in on the 4.01 where the on the 4.0 is just simply is smoother when applying the gas.
      10-29-2012, 10:34 AM   #6
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
open both in ATR and check the Throttle table.
      10-29-2012, 10:36 AM   #7
gmazzu
19
ya thats a good idea. I just filled out the request for the race tuner
      10-29-2012, 11:59 AM   #8
gmazzu
19
just looked at it, i dont see much difference
      10-29-2012, 12:06 PM   #9
enrita
enrita's Avatar
Sweden
161
you could try to copy it over to the 401 and see if it changes anything.
