10-18-2012, 07:36 PM | #1 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
Oil Filter
Does anyone know if the oil filter is the same for the 2.0 and the 3.0? If not can someone give me a part number and brand for the 2.0? The help is much appreciated.
10-19-2012, 12:43 AM | #2 |
288
Rep 1,892
They are different.
328i filter kit part # is: 11427640862 http://realoem.com/bmw/showparts.do?...34&hg=11&fg=30 335i filter kit part # is: 11427566327 http://realoem.com/bmw/showparts.do?...65&hg=11&fg=30 |
11-20-2012, 12:58 AM | #3 | |
33
Rep 391
Is it the element that needs to be replaced? On most cars, I'm used to seeing just one big cannister. You remove the entire canister & replace it with a new one and throw away the old oil filter cannister. I've never had to disassemble the cannister itself to change the filter. Am i reading the diagram correctly?
2018 BMW X3 xDrive30i M Sport
[sold]2013 BMW X3 xDrive30d [Sold] 2013 F30 328i |
11-20-2012, 07:57 AM | #4 | |
BMW Certified Technician
Rep 19
Pull the filter out of the cartridge Change the o-rings with the ones supplied Push the new filter in the same way the old came out Put a bit of oil on the large black o-ring at the top Re-install cartridge into Filter housing, torque and voila! |
11-20-2012, 06:28 PM | #5 | |
33
Rep 391
I am planning on doing this early after 4000kms when the car is new. So there will potentially be lots of metal filings dripping out of the filter as I remove it or at the bottom of the housing. Any tips to mop these up? I change the oil when the engine is warm, so I suppose to let the engine oil cool down a bit before attempting the procedure Thanks!
