F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Any way to get more growl out of 328i?
ARMA SPEED
      10-17-2012, 07:44 PM   #1
edgarik
Drives: 328i Basic Auto
I have a baseline 2012 328i sedan, I was wondering if there is any way to get some more engine sound out of without opting for a 1200$ exhaust.
I really like how it sounds when you turn it on a cold start then the growl disappears.
      10-17-2012, 07:49 PM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Check this thread out, should be exactly what you're looking for -> http://www.f30post.com/forums/showthread.php?t=676468
edit: lol, just saw you were the most recent post in that thread. Have you tried it out?
-Matt
| Z4M Build Thread | @violetnites | flickr |
      10-17-2012, 09:16 PM   #3
edgarik
I did but it doesnt really say how to do anything
      10-17-2012, 09:54 PM   #4
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
See my dyno thread below on the new exhaust.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      10-18-2012, 02:52 AM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Ah, I did it for kicks, it's pretty easy. Will require getting on your back and looking around the muffler section. There's a 'spring' loaded flap that, if you remove the 'spring', you can secure the flap open.
-Matt
      10-18-2012, 08:34 AM   #6
Jamesons Viggen
For maybe $50 you could have the resonator cut out and straight piped. The standard exhaust is pretty well crafted. It's mostly 3".
      10-18-2012, 12:22 PM   #7
edgarik
I looked under next to the inside exhaust there is this small u shaped spring that connected in between 2 bolts, do I pull that out? How do i make the flap open?
      10-18-2012, 01:06 PM   #8
edgarik
I took out the u spring I just dont get what people mean by securing the flap? do i turn the 2 bolts that the U spring was between clockwise or something
      11-30-2012, 08:19 AM   #9
MCD
Brazil
8
Drives: F30 328i
Did any of you delete the resonator already?! I've changed the DP, and was willing to get a sporty sound. Deleting the resonator and using a race DP will make it sound good or maybe it's too loud?!
      11-30-2012, 08:41 AM   #10
slmdgee
Usofstance
Drives: 328I 6SPD
I am going to wait for an exhaust.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      11-30-2012, 12:32 PM   #11
Sock_Puppet
Sock_Puppet's Avatar
Drives: 2013 328i
Personally, I've run into one individual with a "racey" downpipe and found that it, to me, just sound really good. There's not a lot of drone inside the cabin as the sound-proofing done by BMW is quite good but, take my opinion with a grain of salt.
      12-02-2012, 01:03 AM   #12
MikeVictor
Australia
210
Drives: anything given a chance
Downpipe without cat's will give you what you're after for a bit less than an axle-back. As a few guys above said, the stock system is actually pretty good work.
I'll be springing for the M Performance exhaust myself rather than fiddle with the DP's this time around, but as you said that's out of your price range.
      12-02-2012, 05:24 PM   #13
MCD
Brazil
8
Drives: F30 328i
What do you do with the control valve when replacing the stock exhaust?!
f30post
