Quick Vargas Turbo Stage 1/2 Update
10-15-2012, 11:43 AM | #1 |
136
Rep 1,202
Hey guys sorry I have been MIA from this forum for a while. Been super busy. Just wanted to keep you guys in the loop on how things are coming along. I have decided to add a few more upgrades to our turbos and am having the wheels cast and the parts manufactured as of right now. The differences are, for the turbine wheel, after talking with quite a few people including some people at BW I have decided to go with a full back turbine wheel as found in the EFR turbos by BW. I am having one custom cast to my specs to fit these turbos. I am also upgrading both piston rings turbine and compressor side with step gap piston rings, as well as increasing the width of the compressor side piston ring to help curb the oiling issues these turbos have. Stock Compressor side piston ring is .8mm, TD04(RB) piston ring is .95mm we are using a custom 1.1mm piston ring with the step gap design to help stop the oiling issues. These are just small upgrades nothing ground breaking I have decided to include in our turbos to make them as efficient and to give them as much longevity as possible so you guys can have a great product.
Small quote from BW on the benefits of a full back wheel "The fullback wheel hubs employ a full aerodynamic back-disk, meaning that the hubline extends all the way to the inlet tip. This feature allows for incredibly smooth (low energy loss) guidance of exhaust flow out of the housing and into the blade channels." See picture of fullback turbine below if you are not familiar. Also if you do know what a step gap piston ring is see picture below. Basically a standard piston ring butts up against it self to seal but still has a gap for oil to escape through. The Step gap closes more completely and is used in almost all industrial applications because of its ability to better control oil. There is NO solution to keeping all oiling issues in check but these small steps will help in the battle. These are for Stage 1/2. Stage 3's are Garrett turbos Last edited by Tony@vargasturbotech; 10-15-2012 at 01:04 PM.. |
10-15-2012, 11:54 AM | #3 |
70
Rep 2,626
Good stuff Tony! Keep up the great work
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
10-15-2012, 02:10 PM | #5 |
8
Rep 374
This is good news. I just replaced the piston rings on my hy35 Holset turbo and that piston ring looks much nicer :-)
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
10-16-2012, 07:29 AM | #6 |
168
Rep 1,261
Awesome work, looking forward for stage 3 updates.
08 AW 6MT | MHD | Wavetrac LSD 3.46 | AE Quad | VRSF DP'S | VRSF 7" IC | DD Hood / Diffuser| Mtech Front / Rear| BMW Performance Splitters / Spoiler | Wheels 18lb 18x9 SQ | Hexon RR550 | TFT Inlets |
10-16-2012, 11:27 AM | #7 |
242
Rep 2,781
Drives: E90 335i Racecar
This keeps getting better and better!!! Can't wait for these puppies to be installed!!! Tony, is this going to back up the timeline for stage 2?
Michael Lewis
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
10-16-2012, 12:21 PM | #8 |
422
Rep 4,499
Tony your the man!
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
10-21-2012, 09:35 PM | #9 |
422
Rep 4,499
BUMP!
10-21-2012, 10:40 PM | #12 |
130
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
If your stage 2 turbos are as awesome as i expect, i know where ill be going when my stockers poop out on me
