F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > low oil
ARMA SPEED
      10-12-2012, 03:14 PM   #1
awwwyeah206
11
Drives: 335
low oil
Low oil light came on and took it to dealer and they had to add a quart. I'm at 8k miles. I said isn't it alarming that oil level is low on a new car? The service guy said "have you owned a bmw before??" I said no but generally with any car you don't lose oil right? He said it's not abnormal to have to top off between service.
What's the deal? do all you guys have oil hanging out in the garage? is he full of it?
      10-12-2012, 03:36 PM   #2
kokopuffs405
Yup
kokopuffs405's Avatar
104
Drives: BMW?
2014 BMW M5  [0.00]
Same thing happened to me, 13k miles
Went to service , quick and easy
Very typical of turbo engines to burn oil
Oh hello
      10-12-2012, 03:43 PM   #3
alienranch
19
Drives: 2012 BMW 335i
Had the exact same conversation with my dealer last week (10K). Apparently completely normal. All internal combustion engines consume some oil, albeit not much (unless there is a problem). Replacing every 3,000 miles keeps this from becoming an issue. It all boils down to the interval between oil changes that makes this small consumption apparent. The high performance M cars will burn about 1 quart every 4,000 miles. For our car, I heard every 8 - 10K is the average per quart.
      10-12-2012, 04:05 PM   #4
awwwyeah206
11
Drives: 335
thanks for verifying. I guess there should be lots of us hitting 8-10k miles now. I'm wondering if all of the 335ers are running to get oil.
that's pretty inconvenient to have to bring the car in for oil and then not too long later again for service.
      10-12-2012, 04:17 PM   #5
Turbo00
Drives: 2013 328i M-Sport
I'd say it's more a function of the extended service intervals. Sure, every engine consumes oil...just shouldn't be over a short interval. Personally, my old Saab turbos never used a drop - being down a quart at 8k is significant, keep an eye on it.
      10-12-2012, 04:24 PM   #6
ƒ°
ƒ°'s Avatar
101
Drives: ✚
At 7k I got the low oil indicator. I just bought a quart of Mobil 1.
      10-12-2012, 05:36 PM   #7
gt1206
Drives: 2013 F30 328 M-Sport EBII
What brand, weight, viscosity would I have to add should this happen in the near future? N20 engine....
      10-12-2012, 06:12 PM   #8
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
My car alerted me at 6000, asking for topping off because it was getting close to the minimum oil level...
so i took the car in at around 6000 miles, then again at 9000 miles
is my 335i that thirsty for oil ??
My First service is due in 3ooo miles to so, perfect timing for changing the oil and topping it off with fresh ones.
      10-12-2012, 07:42 PM   #9
Humble_Bear
Drives: 01 530i,10 Golf,11 Sorento V6
BMW's 15K oil change interval is too long. You should have another oil/filter change in between instead of topping.
      10-12-2012, 09:16 PM   #10
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
All turbo cars burn oil!! This is my first BMW but not my first car with a turbo so I know its normal. It actually took longer than expected mine came on around 7000miles. process was quick and easy.
I drove straight to the service area and told the guy standing out there he goes to a cabinet they have setup outside grab a quart fill it and run engine check from idrive. no paper work or exchange of names or anything. process was under 10mins.
      10-12-2012, 11:35 PM   #11
dc_bmw
Netherlands
15
Drives: BMW 330e
I have a 1L bottle of oil in the back under the trunk plate. It came with the car and was explained during delivery as an emergency stash.
It is next to the case of lights.
      11-18-2012, 01:44 AM   #12
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Oil Light at 760mi
That doesn't seem right. Going to bring it in Monday morning for a quart.
F30 Sapphire Black M-Sport 335i 6MT
      11-22-2013, 02:41 PM   #13
kamloops
Drives: 2012 335i
2012 BMW 335i  [0.00]
Yep, the process was simple for me and my 335i. As others have said, it's normal for a turbo. For me it happened in the first few thousand miles
      11-22-2013, 03:17 PM   #14
snowghost
snowghost's Avatar
I used my own oil. But does our maintenance include topping off the oil? Thought I read BMW isn't doing that anymore.
f30post
