Upgraded Boost Solenoids?
10-12-2012, 03:58 AM | #1 |
112
Rep 2,621
My car is significantly overboosting in the low to mid range (19psi on map 0).
This has been happening before and after new turbo replacement. I now think this may be the boost solenoids playing up - I'll be testing them tomorrow. Just wondered whether I should buy OEM replacements or whether there are some recommended after market options to consider. I'm FBO, stock twins with Meth.
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
10-12-2012, 04:28 AM | #2 |
161
Rep 7,377
no aftermarket option as far as i know and i dont see how those could be upgraded. they work fine.
10-12-2012, 05:01 AM | #3 |
112
Rep 2,621
Ok great, I'll go OEM.
I know that there are aftermarket boost control solenoids available for Subaru's and EVOs etc which claim to lower WG Duty cycles etc. Just wondered whether there was anything similar on this platform. http://www.wrxtuners.com/forums/f70/...lenoids-25587/
10-15-2012, 02:13 AM | #4 | |
14
Rep 455
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
11-15-2022, 11:39 PM | #5 |
Rep 72
Drives: BMW 335i
Sorry for bump a very old thread... but I think that MAC Single turbo solenoid could do the job well. My mechanic (he's more a tuner than a mechanic tbh) will retrofit them to replace the OEM solenoids. I'll keep you informed.
