F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Rear brake pads due for service in 2800km?
GetBMWParts
      10-11-2012, 08:49 PM   #1
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Not sure if this seems right, I got my my F30 back in April and I'm currently at 10,400km/6222mls and it says that my car is due for service in 2800km for my rear brake pads.
Is this kind of wear and tear normal or would there be something wrong with my original brake pads? My front brake pads say that I still have about 50,000km left on them.
      10-12-2012, 06:48 AM   #2
jwilly
9
Drives: They're all white now.
How much of the brake pad is left? Inside compared to outside? Left side compared to right side? Or are you just relying on a message from the car?
Joel
That's a lot of white
      10-12-2012, 07:57 AM   #3
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
I have a 320i Auto F30. My idrive said the brake pads needed to be serviced in 19.000km (front) . My F30 has now done 11.000km's.
Went to the dealer and had them take a look at it. Now its been reset to 31000km service.....
      10-12-2012, 08:38 AM   #4
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
No way the pads should need replacing at that point.
Either theres something mechanically wrong with the brakes, or the sensor is funked. You should be able to look at the actual caliper and see how much pad is remaining.
The rears on my last car lasted 95,000 miles, and still had 2-4mm of pad left.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-12-2012, 08:48 AM   #5
MaestroAl
United Kingdom
25
Drives: 335xD
Yeah rears can go 50k miles easily unless you're braking really hard all the time. Even with really hard use, I'd expect at least 20k miles.
Just stick your hands through the spokes in the rear wheels and check for yourself.
"Sleeper 335D xDrive M Sport" Glacier Silver / Black
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH
      10-12-2012, 10:46 AM   #6
J1n
65
Drives: R8 V8 '14
They're soft but not that soft =)
      10-12-2012, 11:28 AM   #7
WPGM5
WPGM5's Avatar
Drives: 2015 M5
My '07 E90 went to the dealer 3 separate times for the brake wear sensors telling me it was time to have them serviced. It was just an annoying glitch.
I swapped my pads at 45000 km for cool carbons along with new rotors and still had plenty of life in the oem pads.
'15 F10 M5 (Destroyed by a damn garbage truck)
      10-12-2012, 11:35 AM   #8
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
F30 uses rear brakes as an electronic diff, maybe OP is some 'Dorifto Kingo' wannabee
      10-12-2012, 12:00 PM   #9
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
my car is due for service at 9600 miles due to rear brakes.
      10-12-2012, 12:34 PM   #10
Mako
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1549
Drives: '23 M3 comp
go to your dealer if you want the message fixed. Just took in our X3 that has 15K miles on it(2012) and they adjusted it because they said there was something wrong with the software saying the brakes needed replacing sooner than they really do. I am guessing its the same issue on the F30.
      10-12-2012, 12:46 PM   #11
jwilly
9
How do the pads look?
Joel
      10-12-2012, 02:35 PM   #12
MaestroAl
United Kingdom
25
Drives: 335xD
Interesting. How effective is that gonna be in snow d'you think?
      10-12-2012, 03:40 PM   #13
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
This could be it. Well thought.
But don't stick your hand through the spokes immediately after driving hard.
Unless you like eating your own KFC fingers....
Cheers
Robin
      10-16-2012, 12:17 PM   #14
jwilly
9
Bump for info. Would like to see photos of worn out pads with low mileage.
Joel
      10-16-2012, 03:29 PM   #15
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
Joel
Just got back my car from the dealer and they said my pads are still new and its a software issue which they have updated.
      09-19-2013, 11:31 AM   #16
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
Found this old thread via serach and thought I would post my question here...
I have 2012 335i and had it in for initial service recently at 14,700 miles.
There is a note in the report that says:
CBS data shows rear brakes due in 2858 miles, client had 14,701 miles, inspect and advise.
Then it says:
Rear brakes at 11mm
SA never mentioned anything, so not sure if 11mm means the alert was incorrect. I would think so if it means I have that much pad left, ~ 0.43 in. but I don't know starting point and when they need to be replaced.
2012 F30 335i 6MT - Imperial Blue w/Everest Gray: Sport, Adaptive M, Premium, Tech & Parking Pkgs, Assist, Apps
      09-20-2013, 07:00 AM   #17
jwilly
9
You can replace them when the pad material is the same thickness as the backing plate, as a rule of thumb.
Joel
      03-14-2014, 08:42 AM   #18
Square&Compass
Drives: 328xi sedan
I am at the Dealer now with 8,600 kilometres and need the front and back brake pads replaced due to rust on the rotors wearing out the pads. Does that make sense ?
      03-17-2014, 07:19 AM   #19
jwilly
9
No.
      03-20-2014, 08:07 PM   #20
MyFragileHalogen
450
Drives: '16 M4 6MT
No way for 2800km, unless you go to a track every weekend. My dealer said F30 has some issue with the system. If you take your car to the dealership, they will probably just reset the system.
I had a good amount of fun during 1st year with F30 with a lot of caynon driving, and my pads got replaced at the dealership at 8800 miles. For normal driving, they should last at least 20,000 miles.
      03-21-2014, 01:15 PM   #21
casualDIYer
446
Drives: 340i xDrive M Sport
Agree with above. 2800 is way too fast unless you were tracking the car.
Although lots of theories abound I guess the next question is why is your car doing that while others don't. Maybe a faulty sensor?
      06-30-2014, 12:09 PM   #22
YeaG30
YeaG30's Avatar
Drives: 2017 540i
Just took my 328i in for service with 30,500 miles. The on-board computer told me that I needed oil service, brake fluid service, and system check service. The front and rear brake service indicators said I had 1400 miles remaining. I decided to take it in to see if they could just do all of the services at one time as opposed to making two separate trips.
The SA told me that he did the oil, brake fluid, air filter (cabin), and system check was completed but the front and rear brakes had 10mm and 9mm, respectively, remaining. He said the "software" had to updated and the brake sensors were getting a false reading.
I have not picked up the vehicle yet to actually read what the remaining mileage/time is for the brakes after the update.
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
f30post
