F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Winter wheel setup - 335i
GetBMWParts
      10-08-2012, 11:05 AM   #1
HavannaF30
Drives: 335i
I'm preparing to swap out my stock 19" 401 wheels with a winter setup. With the ridiculous prices that BMW wants for a new winter tire package, i'm trying the 2nd hand route, more specifically from an E90. After searching high and low, I'm still unable to find a clear answer with regards to what will and will not fit on my car.. so i'm asking for anyones insight.
My car is a 2012 335i (non xdrive)
It's canadian so it doesn't have the TPMS, however, it has the FTM.
Does anyone know if a 17"+ set up from an E90 will simply bolt on (with no FTM issues). Or will I need adapters and sensors, making the operation a bit more painful.
Thanks
      10-08-2012, 11:38 AM   #2
ChiefBroady
Drives: 2013 328i M sport
With no tpms it should just be an issue of recalibrating the abs sensors (which measure the wheel speeds to sense the flat tire) which can be done in the iDrive.
But I see another issue here. Wheels from the e90 have different offsets then the f30 ones.
2013 328i M-Sport, EB2, DHP, Adaptive Xenon, CA and some other stuff.
      10-08-2012, 12:22 PM   #3
DerekS
DerekS's Avatar
197
Drives: '24 X3 M Sport
As ChiefBroady pointed out above, the offsets will not be the same if you try to use E90 wheels, nor will the tire sizes match.
You will need either 225/50R17 or 225/45R18 winter tires for your 335i, but if you have M Sport brakes, you would need a 18" set-up.
My suggestion would be to look @ Tirerack for a winter set of wheels/tires.
BMW Canada recommends the Pirelli Sottozero II snow tires for the F30-335i. Tirerack sells these tires. You might also wish to pay attention to the country of origin for the wheels offered by Tirerack; many of them are made in China.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
      10-08-2012, 01:31 PM   #4
pops_f30
pops_f30's Avatar
United Kingdom
23
Drives: F30 330d MSport EBII
Winter tyres on the 19" 403 M wheels.....will this work, I'd rather change the tyre than have another set of wheels in the garage and wondered if you guys had a view on this?
Pirelli have a Winter variant that will fit
      10-08-2012, 02:11 PM   #5
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
As I've said in numerous threads. I have 235/35R19 Nokian Hakka R on my 403M's. I have used 19" winter tyres for years and I live in Sweden so we get real winters up here.
Is it the best option? No.
Does it work? Yes.
I have yet to encounter any real issues with this setup (19" winters in general). My dad runs it on his Lexus IS-F too (same tire and size).
      10-08-2012, 04:27 PM   #6
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
You mean just have one set of wheels, but two sets of tires, summer and winter.
I rather have two sets of wheels, probably cheaper in the long run, and I don't think it's good for the tires to be put on and off wheels several times.
      10-08-2012, 06:17 PM   #7
Maz335i
BMW 4 Life...
Maz335i's Avatar
148
Drives: 2015 SO M3 (on order)
^ This...
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      10-08-2012, 07:23 PM   #8
ocso1606
ocso1606's Avatar
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
Agree! Two sets of rims are always a better option.
M5 with lots of goodies
      10-08-2012, 07:34 PM   #9
SPACEMANRICK
51
Drives: 2016 M3 6 speed manual
Not sure if anyone has seen this yet but I found this on a X3 forum........ Basically for those with mild winter temperatures (like it is here in Vancouver 95% of the time from November to February when the average temperature during the day is about 8 degrees celcius), most winter tires are terrible at braking and handling in warmer temperatures and the only tire (the Pirelli) that performs decently in the milder temperatures rated very poor for ice conditions. I had Pirelli winter tires on my previous 2006 330i and can concur that in places with a mild winter that rarely gets below freezing and rarely snows, snow tires are just too much of a sacrifice in noise, comfort, and handling for 95% of our winter.
For those in warmer climates (like Vancouver) that rarely snow I suggest instead of a snow tire an aggressive all season tire or a set of snow tires mounted on an extra set of wheels that you can take on and off yourself since you will only really need the snow tires on for an average of 2 or 3 days a year. Winter tires kept on for the winter make sense for most of Canada but in Vancouver you will just be driving unnecessarily around with soft, gooey, noisy tires for 95% of the winter.
http://x3.xbimmers.com/forums/showthread.php?t=751470
      10-08-2012, 08:35 PM   #10
Il Fenomeno 415
In top form...
Drives: '13 335i xDrive coming...
Thanks
have you driven the 19" staggered set on snow at all? If so were there any issues with 19" wheels? I'm debating if I need to keep an 18" wheel set for Chicago winters but would prefer to just keep the 19" wheels on all year round.
      10-09-2012, 07:01 AM   #11
derek335i
Drives: F30 335I
i have just order a set of winter rims and tires, brand new. cost me $1800 CAD.
i dont think you can fit in a 17' rims. i went with the 18'.
let me know if you need any info.
      10-09-2012, 07:32 AM   #12
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
I test fit my E92 set up and they do fit on my 335 with standard brakes. 17x8 et34 square. I need to go up a size for the rubber however.
      10-11-2012, 01:36 PM   #13
HavannaF30
Drives: 335i
Is there a technical reason why you need to bump up the tire size? I'm currently looking at style 270 m3 wheels with 235/40/18 square as opposed to 225/45/18, anyone foresee any problems with using them on an f30?
      10-11-2012, 06:22 PM   #14
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
Well my e92 set up was 225-45-17.
      10-13-2012, 09:29 AM   #15
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
I had a winter set for my '09 335i and Tire Rack confirmed I could use them for my '13 F30 335i. They could have told me "no" and I would have bought another set and sold the old one, but they said it would work.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      10-14-2012, 09:27 PM   #16
ocso1606
ocso1606's Avatar
Drives: 2013 335i M
2010 Volvo  [0.00]
Buy from tire rack
f30post
