M5POST
Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Sponsors Classifieds
      10-04-2012, 06:13 PM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
iND | KW Suspension for Your M5
KW Suspensions GmbH was founded in 1992 in Murrhardt Germany and has grown to become a leading suspension tuner for European and Japanese cars. KW suspension is developed thoroughly by KW’s engineers to have an extremely long service life and create a balance between great handling and a comfortable ride quality. KW has equipped winning race teams for over a decade, and is a supplier to AMG as well as BMW in the M3 GTS. KW’s facility is one of only 15 facilities worldwide to be equipped with a 7 post suspension test rig, giving regular M enthusiasts access to Formula 1 technology.
KW Variant 3 [35220098]:
KW’s Variant 3 suspension for the F10 M5 offers a comfortable ride quality with progressive rate springs, a wide range of height adjustment, and adjustable compression and rebound damping. The damper housings are constructed from stainless steel for corrosion resistance and high strength. An EDC compatible model is available which includes a module to defeat the M3’s built-in electronic damping control, and prevent any check engine light when removing the system from the car.
KW 3-way Adjustable ClubSport [39720297]:
KW’s ClubSport suspension for the F10 M5 is created with track day and driving school enthusiasts in mind. The ClubSport suspension retains the stainless steel damper found in the Variant 3 but replaces the standard progressive rate springs with linear rate springs for crisper turn-in and more consistent suspension response. The ClubSport suspension gives a wide range of lowering adjustment, damping adjustment in rebound and compression, and front camber plates with a sealed bearing for front camber adjustment. An EDC module is available for an additional charge and will cancel any error codes caused by removal of the factory EDC suspension.
Please contact a IND representative if you have any further questions.
KW Variant 3 w/EDC Bundle:
KW 3-way Adjustable ClubSport:
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      10-19-2012, 09:47 AM   #2
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Photos during installation of the 3-way adjustable Clubsport. Although this is the more serious suspension offering from KW the ride quality is still very reasonable. For clients that use their beast as a daily driver the Variant 3 is a perfect lowering solution.
