09-27-2012, 11:22 AM | #1 |
86
Rep 186
Will E46 M3 rims fit?
I have my ZCP rims from my E46 M3 and just wanted to know if they would fit my F30 328i with H&R super sport springs. The sizes are 19" x 9.5" with a 27mm offset for the rear and 19" x 8" for the front with a 47mm offset. Thanks
09-27-2012, 12:06 PM | #2 | |
310
Rep 3,572
Rear is aggressive for the F30, you can pull it off by running stretch tires and some negative camber. I would suggest 255/30-19 in the rear. Last edited by jose_sonictuning; 09-27-2012 at 12:27 PM.. |
09-27-2012, 12:09 PM | #3 | |
191
Rep 802
My rears are 9.5" w/ +38 offset, and they are 9mm out from stock (which is essentially flush w/ the fender). Your rims would stick out another 11mm (so 20mm vs. stock setup). Will look really bad and will for sure hit the fender. Fronts - I am going w/ a 8.5" w/ +35. Stock is 8" w/ +35 offset, so you are going to be really far inward (+12mm) and would suspect that you might hit a number of components on the inner wheel well).
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
09-27-2012, 12:09 PM | #4 | |
191
Rep 802
http://www.rimsntires.com/specs.jsp
09-27-2012, 12:23 PM | #5 | |
86
Rep 186
