09-24-2012, 04:03 AM | #1 |
40
Rep 104
Is break in necessary?
I'm about to take delivery this weekend and was wondering whether the "break-in" is still necessary for the F30? It is a 320d sport line.
Can I just drive normally? (Although I am quite an aggressive driver I must say). Regards. |
09-24-2012, 07:32 AM | #3 |
84
Rep 729
This has been discussed many times and you'll get all sorts of responses.
My own view is that the BMW manual tells you to break the car in so there must be a reason for it, although I admit I haven't seen what it specifically says for the 320D. It's your decision though of course. |
09-24-2012, 07:55 AM | #4 | |
301
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
But yes, it's your choice.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
09-24-2012, 07:57 AM | #5 |
411
Rep 1,157
When I picked up my 320d M Sport I was told there was no need to have a break in period and to just drive the car how I wanted.
I must admit though I've still been a bit cautious with it though just in case.
Current: recovering slowly
Previous: F31 340i Ruby Red IIM5 Singapore Grey, F30 335d Moonstone, F30 320d Tanzanite Blue |
09-24-2012, 10:44 AM | #8 |
99
Rep 2,323
09-24-2012, 11:07 AM | #9 |
411
Rep 1,157
That's the one. The one from the dealership who will charge a fortune to put everything right after driving the car without observing the break in period
09-24-2012, 08:21 PM | #10 |
Rep 7
Drives: 2012 BMW 328i
My dealer just told me to not go over 90 mph the first 1000 miles. I'd drive in Eco mode and keep the rpms low for that 1000 miles as well!
'12 328i [Mineral Gray ext./Black Leather int.]] - [Prem/Tech/Park Pkgs] - [Suntek CXP 35%, 70%, & 80%]
09-24-2012, 10:25 PM | #11 |
49
Rep 158
I wouldn't necessarily keep the RPMs low, but I wouldn't go over the RPM limit in the manual during the break-in miles. My manual says to limit RPM to 4K so I stay below that, but I do let the engine rev up to that point occasionally without using full throttle acceleration. Some of the components need to get seated and conformed to their mating surfaces and so I let the engine work its way up to 4K and then switch into Eco Pro and let the engine drop to a lower RPM. I plan to keep my car for at least the next 8 years so I won't abuse it, but I do recognize that the engine needs to do some work to loosen up a bit and start making all its power.
09-25-2012, 11:17 PM | #12 |
890
Rep 7,047
I've got about 1100 miles so far on my 335i Msport.
It's seen red line a number of times all ready, along with a few full throttle accel runs, all well before 500 miles on it. No WFO from standstill yet, but very soon. Within the first week of getting my car I did what I've done with all my new cars and bikes. I do a moderate slow accel to redline in 1st, then let engine braking bring it back down slowly until around a bit above idle, then 2nd gear accel moderately slow to red line and let the engine slowly decrease revs, repeat with at least 3rd and as much with 4th as speed conditions allow. The purpose is to let the engine run to it's maximum rpm and then let the natural vacuum and friction bring it back down, thus allowing the rings to fully do their job and mate well with the cylinder wall, and for all the engines whirrly bits to get full rev and mate with each other. This is one area where you don't want "loosening up". Piston rings help provide the needed seal for maximum compression of the air/fuel mix, which leads to best efficiency and power production with least blow by, meaning, keeping the oil away from the combustion chamber, and keeping the gasoline out of the oil supply. Keep all the bits happy and working in harmony. This engine has shown itself to be very strong and powerful. It feels even stronger than the N54 in my previous 135i. This 335i is a bit heavier than my 135i, yet it feels stronger and faster. I got a good one and want to make sure I give it a good initial wear in. The only thing I don't do is WFO standing starts all the way to red line a la drag race style before 1000 miles. After that, it's ON! |
10-12-2012, 01:15 AM | #13 |
42
Rep 537
Drives: 2013 335i M
I tried to be easy on it..just couldnt, im gonna drive it like it was built to be driven.
M5 with lots of goodies
10-12-2012, 08:16 AM | #14 |
38
Rep 387
I don't have my car yet - should be here next week. But I have a Honda with 126k miles that regularly sees 9000 rpm, pulls strongly, doesn't burn any oil - and it was broken in similarly to RPM90's description. I plan on doing something similar with the N20 as well.
Check back in 10 years, we'll see how I did. |
10-13-2012, 02:23 AM | #15 |
Rep 7
Japanese cars are high rev engines though, not sure if German inline 6's are as high.
10-17-2012, 12:25 PM | #16 |
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1545
Rep 2,586
if its a lease, drive it however you want (warranty and maintenance has you covered as long as you aren't abusing it), otherwise I would take it easy for the first 2,000 miles.
